- Location
- Wyandotte, MI (South of Detroit)
I would recommend that you buy Win7 and install that instead of going back to Vista, if you can spend the $100. Win7 runs much better than Vista and is so similar that you won't have any "learning curve" at all,. Win7 runs really well on laptops, especially if you have at least 2GB of RAM and a decent video chip in it. Basically, if your PC ran Vista acceptably (performance-wise), then it will run extremely well with Win7. My .02 worth. Sorry to hear of your problems...
- Win 10 Pro 64bit
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Home built Intel i7-3770k-based system
- CPU
- Intel i7-3770k, Overclocked to 4.6GHz (46x100) with Corsair H110i GT cooler
- Motherboard
- ASRock Z77 OC Formula 2.30 BIOS
- Memory
- 32GB DDR3 2133 Corsair Vengeance Pro
- Graphics Card(s)
- GeForce GTX 980ti SC ACS 6GB DDR5 by EVGA
- Sound Card
- Creative Sound Blaster X-Fi Titanium HD, Corsair SP2500 speakers and subwoofer
- Monitor(s) Displays
- LG 27EA33 [Monitor] (27.2"vis) HDMI
- Screen Resolution
- 1920x1080
- Hard Drives
- Samsung SSD 850 EVO 250GB (system drive)
- PSU
- Corsair 750ax fully modular power supply with sleeved cables
- Case
- Corsair Air 540 with 7 x 140mm fans on front, rear and top panels
- Cooling
- Corsair H110i GT liquid cooled CPU with 4 x 140" Corsair SP "push-pull" and 3 x 140mm fans
- Keyboard
- Thermaltake Poseidon Z illuminated keyboard
- Mouse
- Corsair M65 wired
- Internet Speed
- 85MBps DSL
- Browser
- Chrome and Edge
- Antivirus
- Windows Defender, MalwareBytes Pro and CCleaner Pro
- Other Info
- Client of Windows Server 2012 R2 10 PC's, laptops and smartphones on the WLAN.
1GBps Ethernet ports
