speedlever
I have a Vostro laptop running Win 7 pro x86. I want to upgrade it to Win 8.1 pro x64 and have a volume license key. The optical drive on the laptop is broken so I need to install from a USB stick. I created a bootable USB drive from here:
Create installation media for Windows 8.1 - Windows Help
The laptop boots from the stick, but when I input my license key, a message pops up saying it can't verify the product key.... please check your installation media. I have the laptop connected via ethernet cable, so I don't believe it's a connection issue.
Is installing from a USB stick not supported for a volume license key?
- Windows 8.1x64 pro
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Homebrew
- CPU
- i5-2500k
- Motherboard
- Asus P8Z68-V Pro
- Memory
- 16 GB
- Monitor(s) Displays
- 2x 19 inch
- Screen Resolution
- 1280x1024
- Hard Drives
- 256 GB SSD
1.5GB
2 GB
3GB external
- Case
- Antec Solo
- Antivirus
- Avast free
