64 bit and 32 bit?
I thought the boxed version has both 32 and 64.
    Windows 8 Pro
    AMD FX-8150
    Gigabyte GA-990FX
    8 GB
    NVIDIA GeForce 980
I'm not absolutely certain, but I get the impression that the retail boxed upgrade has both disks.
However, I don't know what Microsoft provides as a backup disk ($15US option) to the $40 download. It'd be nice if it was the retail package, but I don't expect that.
Has anyone received their "backup disk" yet, who is willing to comment?
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
Great. I'll wait and see once my DVD(s) arrive in the mail.
That's what I'm talking about.
A DVD that has 64bit on it, just to make sure.
It's pointless to install an older x64 release JUST to use the upgrade assistant.
The clean install (form DVD / USB stick) will be snappier.
As long as you don't use the 32bit anymore you can use its key for the 64bit. You paid for it and it's you right to use it.
The architecture (32 or 64) is irrelevant, the OS is the same and that's why the key should apply. (unless they changed the rules again).
This worked with Vista and 7. I had a laptop from 2007 and came with Vista 32bit preinstalled.
I formatted and I used the provided key from the case for the 64bit (same OS same edition, Home Premium) on the same machine. It worked.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
Not entirely.
We have DosBox and 16bit on x64 works perfectly.
Given that I have a 16 bit Dos (Not windows) application. What do I have to do to run it on 64 bit Windows 7 or w8? Can I start it from the start button as I do on w8-32? Would it have access to my hard drives and mapped network drives?
    Windows 7
There's one point: if you want to get the $40US upgrade by download, that's done using the (insert expletive here) Upgrade Assistant. The UA offers only the same bit level as the OS from which it's run.
It doesn't require extreme skill to work around that, because it's possible to use the UA to buy and download the upgrade but then to run it on a different PC.
In my own case, I bought the upgrade using PC1. I did the actual download on PC2, and saved it as an .iso. I prepared a bootable FAT32 USB flash drive copy, and installed tn on PC2.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Silverstone FT02B-W
    6Mb cable
Not entirely.
No it wouldn't.
But your DOS apps can access any folder if it's mapped form DosBox.
DosBox is more difficult to use but does the job here.
I'm afraid there's no way to launch a DOS program from start menu and no network drives are even accessible from what I know.
However, you can give it access through "mapped hard drives" and those can be just folders you want the DOS programs to access.
I agree, It's not as fluent as with the built-in DOS support on the 32bit version, but the fact that we're even able to run DOS apps on 64bit is a great deal. So I remain on x64 with DosBox, It's there just for a few old programs I like and there's no need for me to go back to 32bit just for that.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Not entirely.
Sorry for this repost.
My mistake.:eek:
I guess the delete button doesn't work...
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
What you say it's true.
The particular case here is that an upgrade was already paid (about 60$).
And if you already have a key that was provided for the 32bit, you can use it for the 64bit instead.
No need to run the upgrade assistant AGAIN or pay another 40$.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
I thought that the person that started this thread bought the boxed version since they bought it for $67. Doing the upgrade online for $39.99 plus purchasing the backup disk for $15 would be about $54.99.
I'm confused or are we talking one thing here or did this thread split into two....
    Windows 8 Pro
    AMD FX-8150
    Gigabyte GA-990FX
    8 GB
    NVIDIA GeForce 980
You're right.
We said all there is to it, At least I did.
Let's hope the install/upgrade is good this time.
One way or another, you're able to get 64bit or you can stay on 32.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
HI Giroux,
Try clean install and you can have a option for 62 bit OS. There is no chance to upgrade from 32 to 64 bit, you have to try only clean install
    windows 8 pro
