What cause damage to MOV file and how to repair it
    W10 Pro/W8.1 Pro/ W7 Ult
    My MOV files taken by DSLR(Nikon D810) could originally be played by Windows Mediea Player or QuickTime but now many of them can no longer.
    The files were copied from the SD card to a data partition on 1TB SSD(Samsung 850 Pro). They were working right after they were copied to the SSD drive but I do not know in what moment they quit working. JPG files taken by the same DSLR camera are no problem.
    I wonder what could cause the video file problem as above.
    United States
    Windows 8.1 Pro 64-bit
    I would start by looking at SMART status:
    Here is the SMART status. I am suspecting the SSD because I do not recall such problem when I was using conventional hard drives before. As shown below there is one warning. Is this it?
    United States
    Well, that is not good, it could scramble/corrupt data. How are you connected to the SSD? Are you using IDE or AHCI interface for your drives in BIOS? Really should be using AHCI and that error says to check your cable.
    The interface is set for AHCI. The warning seems to be a record happened in the past. To determine if the SATA cable is the culprit do I have to wait and see if the problem recurs after replacing the cable? It appears awfully time consuming process.
Hello, I am not sure if I am posting in the right area. I keep getting the blue screen of death for the last couple weeks, and when I do a sfc /scannow I get this error pcsvDevice_uninstall.mof Cannot repair member file. microsoft-deviceproxy-wmiv2-provider 6.3.9600. So I stopped VMware and...
Recently, my computer had been freezing on the start screen after extended periods of sleep, so I used sfc/scnannow on command prompt as administrator and it gave me the message "Windows resource protection found corrupt files but was unable to fix some of them." I opened the CBS log and it said ...
HI, I'm new here. I run the sfc /scannow like 5 times because when I did it, it broke or damage my HDMI output. The only problem my sfcdetails.txt file shows is that it cannot repair Amd64\CNBJ2530.DPB of the prncacla.inf file due to a hash mismatch. But you already wrote that it doesn't had to...
hi, i recently bought a lamp for when im reading or whatever else i might be doing i dont know can the light from the lamp damage my laptop screen if it is shining on it???
Windows Developer seems to think that my SSD has a problem and it runs a file check on every boot :( I have checked my disc with several apps and they all report it is ok. I have turned off the disc checker for now. Is anyone else having this problem?
