Bluetooth Headphones paired-not connected: no playback
    I'm trying to use my SB270 Bluetooth Headphones. They pair just fine and show up in Devices and Printers. They also show up in my Bluetooth Devices. They however, do not show up in Sound Playback.
    All my drivers are up to date and the headphones' software is also up to date and installed. If I double left click the headphones in Devices and Printers, this screen shows up. I can click connect under audio services and the button grays out as if it is working, but after about a minute, the button is back and the status is still "disconnected."
    I am using a bluetooth keyboard and mouse which work perfectly, so I suspect the issue isn't with my bluetooth but something about the interaction between Windows 8.1 and the headphones' software. This same pair work perfectly when paired to my phone (Samsung S5), and SO's phone (Motorola Atrix Hd), and our home desktop (Windows 7 Home Premium x64).
    I found a thread on seven forums for a similar issue and tried their solutions with no success. At this point, I'll try anything short of re-installing my OS.
    Here are my specs if they help.
    Go to the Sound Panel, Playback section. RIGHT click in an empty are and then check the boxes to show disconnected and disabled devices. See if the Bluetooth headset shows up.
    United States
    Windows 8.1 Pro 64-bit
    Welcome to the forum!
    Would help to know what make of Bluetooth adapter you have, Broadcom, Atheros, Intel, etc.. Do you have the drivers from the manufacturer of your computer? What make/model of computer?
    Did this, nothing shows except for the speakers
    Quote Originally Posted by popeye View Post
    I have an Acer Iconia W700. It's a "Tablet PC" but it's running full Windows 8.1
    Bluetooth is Atheros and it is up to date according to the Acer website.
    win 8.1
    Hi All
    this is my first post , so please be kind to me
    I recently purchased a w700 which came with win 8.1 German language only [single language edition]
    All good as i only use this for watching movies , i also have w500 but the short battery had prompted me to purchase this [w700]
    Now my trouble stqrted when i wanted to pair my bluetooth headphones - nothing pairs to this [w700] though they pair and work just fine with w500
    i have the latest win 8.1 driver from acer but still no go
    Same issue as with user Amitcham
    If i go back to win 8 using recovery CDs and then reinstall win 8 acer drivers and then update again to win 8.1 without updating acer drivers at all - will this fix the issue ?
    has anyone tried ?
    Please help as i am very frustrated that a premium device [w700] not supporting bluetooth headphones
    Eastbourne uk
    Windows 10 x64 Home Build (Version 1709) 16299.98
    Hi sorry for asking but is the symbol for Bluetooth showing in the task bar.
    Also have you tried anywhere else to get the drivers for your w700 bluetooth
Hi, We use an older laptop for our TV and Netflix etc and it works OK, but reading the TV screen from 15-feet back is a pain. I'd like a dock with wifi/cable Network connection to the Internet and a Bluetooth link to a win8.1 tablet. I have a Fire Stick and Chromecast and they do it OK,...
To all, I have been searching everywhere but can not find the solution. In previous versions of Windows, after 2 Bluetooth devices are paired, you can select or connect the device you want to use. You can have device that connect automatically or it can be manual. In windows 8 or 8.1 I can...
Hello, I have Lenovo Miix 2 10 tablet and Creative WP-300 headset. When I listen to music and put the device into Connected Standby it keeps playing nice. But when I pause the playback using controls on the headset, the headphones disconnect and are unable to reconnect automatically. So I have...
Hi, I have recently installed Windows 8.1 and today I tried to connect my phone (Nexus 4) via Bluetooth. The phone did get connected without any issues but didn't give any option for playing music as it did in Windows 7. A Bluetooth audio control would pop up in Windows 7 but that didn't happen....
I fit the "problem" in the title.
I was watching a TV show in my headphones, plugged it out for about an hour, plugged it back in during which time my Dell Inspiron 15 would have gone to sleep about 4 times.. I plug it back in after an hour and the music plays through the speakers and I looked up all solutions. None of them work....
After upgrading to Windows 8, I can pair my Motorola S305 Headphones but they go offline and won't connect . Any assistance appreciated. Stephen
