Dolby Advanced Audio Problem after 8.1
  1. #11
    Quote Originally Posted by Lowgroundflyer View Post
    Finaly here we have the solving problem solution:
    You must uninstall your current audio driver and replace with the newest driver. Beware who the manufacture is.
    In my case i have the Conexant audio HD driver.
    Do not forget to uninstall the Dolby software too.
    In my case i have Dolby Advanced Audio V2.
    then go to : Conexant Audio Software for Windows 8.1 (64-bit), 8 (64-bit) - Notebook , thatīs the Conexant,
    and : http://support.lenovo.com/en_US/down...DocID=DS032125 , thatīs the Dolby soft.
    Download them.
    In simple stepīs:
    1. Uninstall the audio driver ( in device manager search for audio driver - look after the speaker icon )
    DO NOT Uninstall the the speaker driver - it is difference, because ( in my case I have ) there are 2 driverīs
    making the basic audio work. First is the audio driver for software solution, and speaker driver for speaker solution
    Maybe some PCīs have one or two drivers for the audio. btw.
    2. Restart
    3. Uninstall the Dolby Adv....
    4. Restart
    5. Install the new Conexant audio driver from web above
    6. Restart
    7. Install the Dolby Adv.... driver from web above
    8. Restart
    9. Enjoy
    For those who are live sensitive from detailīs : the joke
    Windows 8 has writen that the version of Conexant has no need to upgrade the driver ( 8.54.44.52 ) on the support site is version 8.54.48.0 ( hint )
    I'll try this once I get home. Hope this will work. I am planning to buy new speakers but it feels so bad not having dolby around. Sounds system doesn't sound right.
  2. #12
    i have a acer laptop ASPIRE V5-471G win8 after upgrading to win8.1 my dolby advance audio v2 is not runnning and i cant costumized T^T who knows how to make it working ? helpppppp i have a realtek HD audio driver i downloaded already to the manufacturer the driver for win8.1 but it is still the same
  3. #13
    Quote Originally Posted by Aljurmapandi View Post
    In the downloaded zip file, find PCEE4 folder, you have the installers in it for Dolby Home Theatre and Dolby Advanced Audio v2.
  4. #14
    I have a lenovo ideapad flex 15 and i have managed to install Dolby advanced audio v2 but it will not process the sound, the software doesn't work. This is a replacement laptop and my previous laptop had advanced audio v2 and worked, but that was preinstalled. This laptop did not have it preinstalled when i received it but i found it in the d drive which contained the drivers. I installed it and now i have this problem. I apologize if this in the wrong thread as i am new to the forum scene.
    Any help is much appreciated.
  5. #15
    Quote Originally Posted by brummyfan View Post
    i have done this but not success (
  6. #16
    United States
    Windows 8.1 Pro 64-bit
    I had to also use the Realtek drivers provided by Acer to make mine work on V3 model. Could not use any updated drivers from Realtek.
  7. #17
    Windows 7
    I think that this is going to help you. I had the exact same problem and when I downgraded to Windows 7 again, this file showed up.
    https://www.mediafire.com/?pjr8cs4sso7r59q
  8. #18
    Here's what worked for me....you have to run the compatibility settings to run like Win7. (8.1) Type "mad" without quotes from start page to search...the first hit is -Run programs for previous versions of windows. run wizard for Dolby profile and Demo. Or any other way you can get to it, I'm sure there's more than one. Now I did this even after making sure I did have the conextant driver installed and tried to reinstall Dolby advanced audio v.2 and getting error at startup saying it couldn't start program.
Page 2 of 2 FirstFirst 12
I updated to 8.1 because supposedly, it was to offer features similar to win 7. Instead, it's even worse than win 8. Now, the sound quality on my laptop is lousy because the Dolby Audio driver receives an error message and isn't working. I went to Lenovo (I have a Ideapad N Series 580) and...
Hi guys, I'm having an (what appears to be quite a common) issue with my sound since installing to Windows 8.1 I have an Acer Aspire V3-571G laptop, and was recently asked to upgrade to Windows 8.1. Once I did that, a pop-up has come up saying:...
Hello Dear Friends, I have Asus All In One ET2701INKI, the problem is the microphone does not work properly, It has dense distortion and echo, microphone works in other devices very well, I read many topics in many forums and I tried so many things but there is no solution, I am using...
I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I canīt open it, and when I try it says that I could re-install it. But how?
Lost my Dolby sound in win 8 in Drivers & Hardware
My win 8 package comes stock with Dolby advanced audio. I uninstalled the IDT driver and its software from device manager to roll back to an earlier version to solve a problem.. that didnt work, so i reinstalled the original drivers and it's software as both downloaded from hHP ( see me specs) and...
audio problem in win 8 in Sound & Audio
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
