Hi there, I have recently acquired a gaming PC which has been built up from scratch by a local in my area who has good reputation for reliability etc. Most things are working fine, however I cannot seem to get the sound working through my television, which is my main (and only) monitor. The TV/Monitor is plugged into the PC through a DVI/HDMI adapter since the PC does not come with a HDMI slot. Visually, the TV is recognized instantly as '1.32 LCD_TV' in control panel - display, so the PC knows it is there. However, right clicking sound in the bottom right of the desktop and going to playback devices, there is only Speakers, Headphones and Digital Audio. The PC is not picking up the TV as an option for sound to come out of and that has baffled me. Most of the solutions previously to this problem are to go to playback devices and simply switch, but I can't since the option is not there for me, almost like the TV isn't connected at all.
I went on device manager and tried to update all related rivers but they are all apparently up to date. Furthermore there are no important updates available and the machine is completely up to date. Adobe and Java are installed.
Here is my spec (This is a built PC by an acquaintance of mine)
System Information
Time of this report: 1/2/2013, 02:46:52
Machine name: GAMING
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.121119-1606)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 06/26/12 22:24:35 Ver: 04.06.04
Processor: AMD FX(tm)-6100 Six-Core Processor (6 CPUs), ~3.3GHz
Memory: 4096MB RAM
Available OS Memory: 4074MB RAM
Page File: 1580MB used, 6078MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_042110DE&REV_A2
Display Memory: 2394 MB
Dedicated Memory: 613 MB
Shared Memory: 1781 MB
Current Mode: 1768 x 992 (32 bit) (30Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: 32W_LCD_TV
Monitor Id: OEM3700
Native Mode: 1920 x 1080(i) (60.053Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.0697 (English)
Driver Version: 9.18.13.697
DDI Version: 10
Feature Levels: 10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: 10/19/2012 00:02:42, 18252136 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-42D3-11CF-D771-2C241FC2C435}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x042110DE
Revision ID: 0x00A2
Driver Strong Name: oem3.inf:0f066de307263f12:Section009:9.18.13.697ci\ven_10de&dev_0193
Rank Of Driver: 00E02001
Sound Devices
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_18497892&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.02.9200.16384 (English)
WHQL Logo'd: Yes
Date and Size: 7/26/2012 02:26:51, 339968 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
I am a total novice when it comes to this type of thing so I could really do with some help. I tried looking through the BIOS but that was all foreign to me (not literally)
Thanks
System Information
Memory: 4096MB RAM
Display Devices
Monitor Id: OEM3700
Output Type: DVI
DDI Version: 10
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x0193
Revision ID: 0x00A2
Sound Devices
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Thanks
- Windows 8 Pro 64b
