No sound with w8 and HDMI
Nexus12
Hi there, I have recently acquired a gaming PC which has been built up from scratch by a local in my area who has good reputation for reliability etc. Most things are working fine, however I cannot seem to get the sound working through my television, which is my main (and only) monitor. The TV/Monitor is plugged into the PC through a DVI/HDMI adapter since the PC does not come with a HDMI slot. Visually, the TV is recognized instantly as '1.32 LCD_TV' in control panel - display, so the PC knows it is there. However, right clicking sound in the bottom right of the desktop and going to playback devices, there is only Speakers, Headphones and Digital Audio. The PC is not picking up the TV as an option for sound to come out of and that has baffled me. Most of the solutions previously to this problem are to go to playback devices and simply switch, but I can't since the option is not there for me, almost like the TV isn't connected at all.
I went on device manager and tried to update all related rivers but they are all apparently up to date. Furthermore there are no important updates available and the machine is completely up to date. Adobe and Java are installed.
Here is my spec (This is a built PC by an acquaintance of mine)
System Information
Time of this report: 1/2/2013, 02:46:52
Machine name: GAMING
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.121119-1606)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 06/26/12 22:24:35 Ver: 04.06.04
Processor: AMD FX(tm)-6100 Six-Core Processor (6 CPUs), ~3.3GHz
Memory: 4096MB RAM
Available OS Memory: 4074MB RAM
Page File: 1580MB used, 6078MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_042110DE&REV_A2
Display Memory: 2394 MB
Dedicated Memory: 613 MB
Shared Memory: 1781 MB
Current Mode: 1768 x 992 (32 bit) (30Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: 32W_LCD_TV
Monitor Id: OEM3700
Native Mode: 1920 x 1080(i) (60.053Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.0697 (English)
Driver Version: 9.18.13.697
DDI Version: 10
Feature Levels: 10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: 10/19/2012 00:02:42, 18252136 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-42D3-11CF-D771-2C241FC2C435}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x042110DE
Revision ID: 0x00A2
Driver Strong Name: oem3.inf:0f066de307263f12:Section009:9.18.13.697:pci\ven_10de&dev_0193
Rank Of Driver: 00E02001
Sound Devices
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_18497892&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.02.9200.16384 (English)
WHQL Logo'd: Yes
Date and Size: 7/26/2012 02:26:51, 339968 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
I am a total novice when it comes to this type of thing so I could really do with some help. I tried looking through the BIOS but that was all foreign to me (not literally)
Thanks
    Windows 8 Pro 64b
Nexus12
I went to my motherboard wesbite, my motherboard is a asrock extreme3 and I found this: Realtek high definition audio driver ver:6699.
I downloaded it hoping for a solution when all I got was that instead of there being three options in playback devices, headphones is now also missing. Can someone please help ? :(
EDIT: The realtek augio hdmi driver available on the sticky in this forum did not change anything either
    Windows 8 Pro 64b
Rymax99
You have your video card drivers? That is what the audio is coming from, your video card. Try updating drivers for it.
    Name
    Ryan
    Custom built
    AMD FX-6300
    ASUS M5A97 LE R2.0
    2x4(8 GB) G.SKILL Ripjaws
    Radeon HD 6870
    Acer G245HQ
    2xWD Black 1 TB
    Cooler Master G650M
    Cooler Master n500
    Cooler Master Hyper 212 EVO
    60/12(Mb/s)
    Chrome
    Country Flag
    USA
    State/Region Flag
    us florida
JJG
I had almost the same problem a few weeks ago. Same except for I was using a HDMI monitor not a TV.
Solved it by going to Control Panel/Sounds/Playback and setting the 'Digital Audio HDMI' entry to default (Right Click). You might want to take a look at your playback entries and see if doing that would solve the problem.
Hope this helps.
    Dell XPS 8500
    3.1g Intel Core i5-3350P
    Dell 0nW73C A000
    AMD RADEON HD 7570
    AMD high definition audio device
    Samsung AMB23301
    1TB Manufacturer not known
    Cox High Speen
    Country Flag
    USA
    State/Region Flag
    us virginia
Nexus12
So I've been in contact with the seller of the PC and he said that he didn't have time to install all of the drivers due to limited time, which means I do not know which of the drivers on my PC are up to date and which are not, however, on Device Manager they all claim to be up to date, so I am baffled as to why I am still not getting any sound through my HDMI. And the Realtek HDMI output is already set to default
EDIT: I have sat and attempted to upgrade all the drivers in device manager, each and every one, and they are all apparently up to date. I have hit a brick wall
    Windows 8 Pro 64b
PJL
You say you've hooked up the TV using the DVI output of the NVIDIA GeForce 8800 gtx video card, right? Well first of all, DVI does NOT output audio -- only HDMI does. And your video card does have an HDMI output. So the brick wall you've hit is that you do not have the capability for HDMI audio in your machine. If you had a different video card (like the NVIDIA GeForce GTX 550 Ti (which is the card I have) that has HDMI out, then you would get the sound via the HDMI connection of your TV.
    Windows 7 Professional
Nexus12
MY brother has a GTX 550 Ti card and he has the same problem. So does that means certains PC's will never sound HDMI sound, regardless?
    Windows 8 Pro 64b
Rymax99
No, it's a matter of the video card. If it has a HDMI out, then sure. Store bought PC's these days are getting to have HDMI on the onboard cards.
You can still have audio if you are using a dvi cable to hdmi. You just need to use computer speakers.
    Name
    Ryan
    Custom built
    AMD FX-6300
    ASUS M5A97 LE R2.0
    Radeon HD 6870
    Acer G245HQ
    2xWD Black 1 TB
    Cooler Master G650M
    Cooler Master n500
    60/12(Mb/s)
    Chrome
    Country Flag
    USA
    State/Region Flag
    us florida
Nexus12
Yeah I have resorted to buying speakers since the card does not allow HDMI sound, I would like to say that this is solved however I seem to have ended one problem and created another. The speakers, which are Logitech Z323's, (well, the right speakre only) emits a inconsistent but constant high pitched beeping noise when it is plugged into the green jack on the pc. However, they dont do it when plugged into my ipod or other hardware, so the PC must be the problem. Any ideas?
    Windows 8 Pro 64b
