System Restore Checkpoint Creation / Restore Problem
    Hi,
    I have windows 8 Pro With Media Center installed on my laptop (Vostro 1015 320 GB HDD & 4 GB RAM). I just have the OS, MS office 2K13, foxit reader, KIS 2K14 and Paragon Partition Master installed (which I do not use at all). Since two days ago System Restore Checkpoint Creation / Restore is not working. The error message says that I do not have sufficient privilege for the operation to succeed. Although my machine is working, I need this to work as i have all my personal data on it. A backup is there but can this issue be resolved without a fresh install since volume of data is quite big and important ? Any help would be much appreciated.
    Thanks...
    St. Augustine
    Quote Originally Posted by samrat View Post
    Thanks...
    Are you saying your Restore Points are your only form of Backup for all your data?
    Hi
    That is not at all. This problem has also cropped up on my PC which I use for remote connections to my clients and doing maintenance work, Also I have a lot of important documents on this. I am a Sys Admin and hence from time to time do need to install new S/W or test out different virtual scenarios on behalf of my client. So if anything happens SysRestore is the fastest way to get back to a working environment again. This PC is running Windows 8 with 16GB RAM, 2TB HDDs (2 nos.) and has INTEL i5 on a genuine INTEL board. The H/W is not an issue and I had not installed S/W or changed config when the problem arose. I am totally stumped as I have not faced this before. External System Backup is there but restoration is time consuming and hence my query. Thanks for replying, gator2013....
    Samrat.
    Win8.1
    This thread has some good info and links (at the bottom) hopefully something here will help you Restore Point - Add "Create Restore Point" to Context Menu in Windows - Windows 7 Help Forums
    Also, this may help Built-in Administrator Account - Enable or Disable - Windows 7 Help Forums
    St. Augustine
    Hi
    Samrat.
    Accessing the Built-In Administrator Account might help in your situation per the link provided in the reply above.
    Since you are still running W-8 I wonder if your system is in the middle of some sort of forced install of W-8.1? This has caused problems for other W-8 users. Have you been installing Windows Updates on a regular basis? Have you tried any diagnostics like SFC /Scannow to check for file corruption?
    win8 64bit
    I think this article will help you System Restore Not Working, How to Fix?
    Harrisonburg, Va.
    In the past System Restore Points failed to work for me.
    Now I use Macrium Reflect images on usb drives to restore with.
    Do as you wish.
    Just adding my 2 worth.
System restore not creating restore point in Performance & Maintenance
I went into Task Scheduler and set System Restore to create a restore point every day at 12:01am. Under Conditions I cleared all the check boxes because I want SR to run regardless of whether computer is idle or not. I have been watching this for about 1 week and so far it's not created a single...
How to Enable or Disable Automatic System Restore Point Creation in Windows Restore points are created to allow users a choice of previous system states. Each restore point contains the necessary information needed to restore the system to the chosen state. Restore points are created before...
Hi, This is my first post on the forum. I am of Polish so I apologize in advance for my language errors. Translator, translate the text: p I have this system of seven months, and already appeared first troubling issues with which I tried to deal with, but unfortunately did not bring any positive...
Solved System Restore will not restore in Performance & Maintenance
I make manual System Restore points and when I try to use them to restore, it goes thru the motions but ends up saying System was not restored - returned to previous state. I make Macrium Reflect back-ups regularly and they work great - no problems. So, what I have done is turn off System...
Solved system restore problem in Performance & Maintenance
i have windows 8 when trying to use system restore it gets to the screen that says system restore is restoring files, but that's as far as it gets, I let it run today for 4 hrs. what can i do?
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
