System Restore Checkpoint Creation / Restore Problem
samrat
Hi,
I have windows 8 Pro With Media Center installed on my laptop (Vostro 1015 320 GB HDD & 4 GB RAM). I just have the OS, MS office 2K13, foxit reader, KIS 2K14 and Paragon Partition Master installed (which I do not use at all). Since two days ago System Restore Checkpoint Creation / Restore is not working. The error message says that I do not have sufficient privilege for the operation to succeed. Although my machine is working, I need this to work as i have all my personal data on it. A backup is there but can this issue be resolved without a fresh install since volume of data is quite big and important ? Any help would be much appreciated.
Thanks... :)
gator2013
Thanks... :)
Are you saying your Restore Points are your only form of Backup for all your data?
    Foxcon Joshua-H61-uATX
    8 GB/ LT - 6GB
    Integrated IDT 92HD73E
    Wireless
    Wireless
    IE11
    Norton 360
samrat
Hi
That is not at all. This problem has also cropped up on my PC which I use for remote connections to my clients and doing maintenance work, Also I have a lot of important documents on this. I am a Sys Admin and hence from time to time do need to install new S/W or test out different virtual scenarios on behalf of my client. So if anything happens SysRestore is the fastest way to get back to a working environment again. This PC is running Windows 8 with 16GB RAM, 2TB HDDs (2 nos.) and has INTEL i5 on a genuine INTEL board. The H/W is not an issue and I had not installed S/W or changed config when the problem arose. I am totally stumped as I have not faced this before. External System Backup is there but restoration is time consuming and hence my query. Thanks for replying, gator2013....:)
Samrat.
CountryBumkin
Gv me thumbs-up if I help
    Win8.1
    HTPC: Custom built
    intel i5-2400
    Gigabyte GA-Z68MX-DS2H
    16GB Corsair DDR3-1600
    on-board HD3000
    On-board
    Samsung 32" LED
    eight HGTS Deskstar NAS, 3TB
    seven WD Red NAS, 3TB
    one Seagate ES.2, 1TB
    one 64GB SSD
    Corsair 750W
    Li-Lian case with SuperMicro hotswap backplane
    Case 4 6" fans, stock CPU cooler
    Two 3-Ware (LSI) model 9650SE-8LPML RAID cards.
gator2013
Hi
Samrat.
Accessing the Built-In Administrator Account might help in your situation per the link provided in the reply above.
Since you are still running W-8 I wonder if your system is in the middle of some sort of forced install of W-8.1? This has caused problems for other W-8 users. Have you been installing Windows Updates on a regular basis? Have you tried any diagnostics like SFC /Scannow to check for file corruption?
    8 GB/ LT - 6GB
    Wireless
    Wireless
    IE11
    Norton 360
In the past System Restore Points failed to work for me.
Now I use Macrium Reflect images on usb drives to restore with.
Do as you wish.
Just adding my 2¢ worth. :)
    Name
    David A. Bailey
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Occupation
    Trying to live a good life before I die.
    Opera 24.0
    Avast Internet Security
    Country Flag
    USA
    State/Region Flag
    us virginia
