System restore could not start
    This is the message I get when I try and open system restore. Can anyone help?
    At the same time o0ther serious problems have arisen:
    In control panel>programs and features all programs except those named Mi-Mo have disappeared. Some installed since are there, and those in the quick launch menu still work. Most are also missing from the bstart menu.
    Al;so on start up I get a small window saying explorer.exe with a yellow exclamation mark and nothing else.
    What's happening?
    Windows 8.0 x64
    Try to do a full scan with the free version of
    Malwarebytes Antimalware
    Quote Originally Posted by MilesAhead View Post
    Try to do a full scan with the free version ofMalwarebytes Antimalware
    Been trying to do that but cant install malwearebytes error - no access
    Error 5 access denied. Also cant install AVG anit virus.
    Windows 8.0 x64
    Are you able to enable built in admin account?
    Built-in Administrator Account - Enable or Disable in Windows 8
    Yes.
    Windows 8.0 x64
    See if you can install MBAM in the admin account and scan from there.
    System restore is bad for embedding viruses in the data it saves, so when you restore it releases the virus which really is not great... I run a IT company and whenever we setup business systems we turn of restore... use Acronis ( Best backup software for data protection and disaster recovery instead.. create images and restore in minutes, you can restore over networks and live... restore will cause you grief in the end.. looks like your restore point in your Windows is damaged... back up with live boot, format and reinstall Windows then image and turn of restore point...
    Windows 8.0 x64
    Quote Originally Posted by Jaynik View Post
    Format and reinstall Windows is kind of radiccal before even knowing what the problem is. Reinstall is a fix all that won't disappear. So let's keep it in reserve until some diagnosis is performed. I use backup imaging myself. But if you don't know you are infected the imager will back up infected system files just like the restore point.
    Fair call but i dont wait till my complete system is damaged and BIOS/cache is infected.. from experience if a indows tool is affected and anti virus is not access able, so if you want to do system scans try HDD regenerator, disk check and like i said live boot virus check... all these will take longer then creating an iage and reinstall of Windows and set up system right so you have a reduced risk, also imaging with incremental backups will ensure an intrusion can be fixed fast.. If you cant access anti virus, malware bytes and system restore either HDD is damaged with sector errors etc or Windows is corrupt... although format is as you say radical i bet thats the end result... anywho i offer help in peace and hope you sort it out.... id be using Hirens etc to test HDD for sector errors and attempt to create image just in case HDD is on its way out...
Page 1 of 2 12 LastLast
System restore not creating restore point in Performance & Maintenance
I went into Task Scheduler and set System Restore to create a restore point every day at 12:01am. Under Conditions I cleared all the check boxes because I want SR to run regardless of whether computer is idle or not. I have been watching this for about 1 week and so far it's not created a single...
Solved System Restore will not restore in Performance & Maintenance
I make manual System Restore points and when I try to use them to restore, it goes thru the motions but ends up saying System was not restored - returned to previous state. I make Macrium Reflect back-ups regularly and they work great - no problems. So, what I have done is turn off System...
Dumb question - if I panic and have to do a system restore or system reset using the install DVD for W8 what will happen to the W8.1 version I just downloaded and installed?
Hello to all, A month back I accidentally deleted the wow6432 node from my registry under system_user. I believe this is the root of all my problems. Once I did that, my toshiba c885 D 64 bit would not boot. I forced the computer to shut down and pressed f12 to get to the system recovery...
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
How do I start system restore in windows8 I cant even find it.:dinesh:
