JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Having a wireless problem
I'm having wireless problem. It just won't connect to the internet and I've tried turning the airplane mode on and off but it won't work.
OS
HP g7-2323dx
640GB
Try removing the wireless driver in Device manager, connect with Ethernet cable and establish connection, once you have done that try setting up wireless connection.
OS
Win 8.1
Acer Aspire E1-571
i5-3230m
Acer Type-2
8GB DDR3 1333MHz
Intel HD 4000
High Definiton Audio Device
Generic
1366x768
Samsung 850 Pro 256GB
Generic
QWERTY
ELANTECH Touchpad
12.68Mbps
IE11
Yes, first step would be to connect directly to the router using one of the LAN ports, not the Internet port, and setting up the router.
You haven't given us much information. Is this a home connection? What router and what adapter in computer?
OS
Windows 8.1 Pro 64-bit
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
8GB DDR3 PC3-12800 (800 MHz)
HD4000 + GeForce GT 730M
Realtek High Definition Audio
1600x900 pixels
Samsung SSD 850 EVO 250 GB
ADATA SSD SP900 128GB
90 watt brick
Bluetooth
Comodo
It's a home connection. It's an ATT router and I don't know what adapter is.
OS
HP g7-2323dx
640GB
Again, model number of router would help. I'm assuming it is really a Gateway, those things can be finicky and some are just plain crap. If you go into Device Manager on your computer it will tell you what adapter you have.
OS
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
1600x900 pixels
90 watt brick
Bluetooth
Comodo
I went into Device manager but what do I click on after that?
I'm using the ethernet right now.
OS
HP g7-2323dx
640GB
Retired from the grind
The adapter is what is in your laptop or desktop, to allow you to connect with the gateway. Depending on the Gateway. You could have one that only does Wireless-G, or is capable of Wireless-N.
The SSID & Passphrase are printed on the side of the device, along with the master password. As long as the Gateway shows all Green lights on the front, it is connected to the DSLAM or VRAD. Connect an Ethernet cable to it and the computer. See if you can get to either Google.com or yahoo.com. If you can, then you know you have Internet with ATT. If not. Then your Gateway is not activated on their network.
OS
Linux Mint 17.2
12GB
AMD Radeon™ HD 7310 Graphics
Realtek HD
LCD
1366 x 768
Crucial M500 240GB SSD
Logitech M525
45/6 - ATT U-Verse
None needed. It is Linux.
Seems pretty complicated.
I just plugged off the ethernet cable, and not only does it not connect to the local wireless, it doesn't show any wireless at all to connect to.
Should a different approach be used?
OS
HP g7-2323dx
640GB
If you plug in with cable you are not using wireless, you are then using the LAN connection. Are you plugging the cable into the LAN port of your computer then into the Internet port of the router/Gateway? This is the best way to begin testing.
OS
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
1600x900 pixels
90 watt brick
Bluetooth
Comodo
I believe so.
The cable is connected to the only place where it fits on the laptop and is connected to the router.
OS
HP g7-2323dx
640GB
I believe so.
Well, can you now connect to the internet? If you are in desktop you should see a connection icon in the tray.
OS
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
1600x900 pixels
90 watt brick
Bluetooth
Comodo
I did not ask if it connects to Wireless when you connect the Ethernet Cable. I asked if you can go to google.com or yahoo.com on a browser? Can you or can you not get to either of those websites, when you connect the computer with an Ethernet Cable to the Gateway?
OS
Linux Mint 17.2
12GB
Realtek HD
LCD
1366 x 768
Logitech M525
45/6 - ATT U-Verse
The gateways that ATT uses, a couple of them have a port that is exclusive for use with an iNID. You have 4 ports designated for the Switch part of the Gateway, 2 Telephone ports for in home telephone, and a RJ-11 port for DSL connection to the incoming connection from the NID.
The OP needs to state if they have four Green lights, (DSL, WiFi, Broadband, Internet) lit up on their gateway. Along with if they can get to any websites through their web browser, when connected via Ethernet to the Gateway.
OS
Linux Mint 17.2
12GB
Realtek HD
LCD
1366 x 768
Logitech M525
45/6 - ATT U-Verse
