Hi all
This is a long story so I'll try to keep it brief. Lenovo Thinkpad E540. Came with Windows 8 - I followed the instructions to write the USB recovery media. Installed 8.1 shortly after it became available. A while after Windows 10 came out I thought I'd upgrade, knowing I could always go back to Windows 8 if I didn't like it. Had some problems with W10 (DVD drive was intermittently missing) so decided to go back to W8. That's when the problems started.
Had a hell of a job getting laptop to boot from the USB drive. Changed the boot order to the USB device and it flashed like it was using it but always just booted into Window's 10 recovery features. Choosing the USB options from within that just restarted and I ended up in the same place. After looking around on the web I saw people with the same problem had changed their BIOS options to get it to actually boot from USB. I turned off "secure boot" and some other options and finally I got somewhere. Not the Windows 8 install options I was expecting but recovery sort of options, but running from the USB stick rather than the W10 ones. I chose to reset the PC and it asked me about partitioning. I said to leave the partitioning as is but it wouldn't accept that so I had to choose to repartition. I thought I'd get some options but it just carried on and did it. After that it started resetting and counted slowly up to 100%. Great I thought. After it finished it restarted and booted from the USB stick again. Closed that down took the stick out and restarted. No W8.
Thought I should change the BIOS options back to how they were and Windows will then start. I think I have put them back to how they were (yes, I know I should have made a note) but I still can't get W8 to boot. Previously top of the boot order list was "Windows Boot Manager" but that is no longer there.
I don't know whether my BIOS options are stopping Windows starting or whether the fact that the Windows installer has zapped all the partitions that's stopping it but please can someone advise me? I have a very expensive door stop at the moment!
thanks
thanks
- 8.1
