Weird Problem....... Is my system compromised??
parashar
India
yesterday during normal working of computer it suddenly refreshed means task bar icon refreshed (as when some new software installs task bar icons blinks) i was working that time on my pc..i thought there might be some new software installed on but control panel shows nothing new has been installed..when i checked in software "LAST ACTIVITY VIEW" it shows nothing special but weird symbols like chineese language before file locations(see attachment) this worried me a complete pc scan doesnt shows any virus or malwares so why these special symbols appear here......perviously in my win 7 there is nothing like this symblos and also i cross checked on my another pc running win 8 there is also no such symbols...please help...is my system compromised or something...i am currently running win 8.1 pro
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
No. Just means that the system needs to have a SFc /Scannow to find issues. Maybe do the dism also.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
are you sure broe23 that this/will be the only issue... or there could be something else.???.....could you please guide me how to do these troubleshooting process you mentioned in your post.
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
Odd characters show up when Windows has information that may be screwed up due to when it attempts to write to the drive and data bits are not written correctly. The other is if you are using one language as the main language for your profile, and the software or data is written in a different language. You can get messed up information.
Run a scan with the command 'sfc /scannow' and see if it fixes it.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
how to run the command sfc/scannow and also dism you mentioned
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
still facing the same problem above scan shows shows no issue.......after these scan i feel that my computer started running slow is it so...do this happen after this scan
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
Doing the scans does not slow down the computer.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
What AV and malware programs did you use to scan the computer?
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
eset smart security...if you have window 8.1 pro you can install software last activity view and check if this happen only with me or its a bug in software itself i.e appearance of Chinese symbol.
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
Is your current version of eset smart security up to date and compatible with Windows 8.1.
I would uninstall it using their removal tool if available and see if any changes and speed. You could always reinstall it latter.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Good advice here!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
yes it is upto date sir and also compatible with window 8.1...what uninstall, removal tool and speed you talking about Nuccii?? have you checked it on your system last activity viewer software about these symbols and bugs?
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
Good advice here!
ya there are certainly good advices azasadny but also being provided continues help and effort don't know why same problem still persists.
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
Excellent post ,not everyone knows what is meant by run a scan .
The problem is that when you are multitasking between here and Facebook and watching tv. It gets you into trouble. I always figure that if someone catches that I was too short on the response. They are going to ask for clarification.
I will state one thing though. Windows 8.x.x has made it a lot more difficult in diagnosing problems that were easier to diagnose in Windows 7. It is getting people to clarify if they are attempting to do something in the Metro Interface or Desktop. Also you have the fact that Microsoft messed with everyone's heads. By making it sound that Metro is the only interface. Most have forgotten that there is still the desktop out there. Due to majority have been spending a lot of time on tablets and/or smartphones and forgot a lot of skills that they had to use with the older OS's.
It is like going through Physical Therapy/Occupational Therapy after a major accident. You have to retrain their minds for those skills they have forgotten about. The other is that most people just turn on their computers, log in and open up the Web Browser. But never dig deeper into what the OS is all about. They have this fear that they are going to break something. If they look around in the various folders, or run certain commands in the Command Window.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
hey all my problem still not solved plz help
    Windows 8.1 Pro x64
    Dell Studio 1457
    Intel Core i7-720qm
    Dell
    4GB
    512 MB AMD RADEON
    Realtek
    1366 X 768
    500 GB 7200rpm
    Dell wireless mouse
    21.6 mbps
