Hello,
I'm having a issue which is complicated and would really appreciate some help.
I have a Surface Pro which hard froze during a windows update and now will not boot at all. It just sits at the 'Surface' logo when you turn it on with the loading circles.
I didn't have a USB recovery key created and I have no access to another original Surface Pro (no stores have them anymore) to make one.
Every USB stick I created with a normal Windows iso's won't boot. My question is can a Windows 8.1 recovery USB made on a friends computer work on any other or is it machine specific?
Thanks
Thanks
- Windows 8.1 x64 Pro
- Computer type
- Laptop
- System Manufacturer/Model
- Surface Pro
