Precision Touchpad Right Clicks - Turn On or Off
How to Turn On or Off Right Clicks for Precision Touchpad in Windows 8.1
A certified Windows Precision Touchpad is a new class of input devices that provide high precision pointer input and gesture functionality. By default, these devices generate ultra-high precision scroll wheel messages for desktop application consumption.
The August 12th 2014 update rollup from Windows Update for Windows 8.1, Windows RT 8.1, and Windows Server 2012 R2 introduced a new feature for precision touchpads by adding the Double-tap and drag setting.
If this setting is turned on, you will be able to right click by clicking or tapping on the right touchpad button.
If this setting is turned off, then when you click or tap on the right touchpad button, it will perform the same as a left click.
This tutorial will show you how to turn on or off the allow right-clicks on the touchpad feature for your account in Windows 8.1 and Windows RT 8.1.
Turning on or off the allow right-clicks on the touchpad feature does not affect being able to still use the two finger tap gesture on the touchpad to perform a right click when you like.
Turn On or Off Precision Touchpad Right Clicks in PC Settings
1. Open PC Settings, and click/tap on PC and devices on the left side. (see screenshot below)​
2. Click/tap on Mouse and touchpad on the left side, and do step 3 or 4 below for what you would like to do. (see screenshot below step 5)​
3. To Turn On Allow Right Clicks for Precision Touchpad
A) On the right side under Touch keyboard, move the Allow right-clicks on the touchpad slider to the right to turn on, and go to step 5 below.​
4. To Turn Off Allow Right Clicks for Precision Touchpad
A) On the right side under Touch keyboard, move the Allow right-clicks on the touchpad slider to the left to turn off, and go to step 5 below.​
5. When finished, you can close PC settings if you like.​
Turn On or Off Precision Touchpad Right Clicks using REG File
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\PrecisionTouchPad
RightClickZoneEnabled DWORD
0 = Turn off right clicks
ffffffff = Turn on right clicks
2. To Turn On Allow Right Clicks for Precision Touchpad
Turn_On_Precision_Touchpad_Right_Clicks.reg
3. To Turn Off Allow Right Clicks for Precision Touchpad
Turn_Off_Precision_Touchpad_Right_Clicks.reg
5. Double click/tap on the downloaded .reg file to Merge it.​
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.​
7. Sign out and in, or restart the PC to apply.​
  • Turn_Off_Precision_Touchpad_Right_Clicks.reg
  • Turn_On_Precision_Touchpad_Right_Clicks.reg
