Won't detect the ethernet cable.
I think that if the last router worked then the problem is with the new router and not the operating system. You should try using another router.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Sorry for being so late, but I've tried it with another one and it still did not work.
    VAIO VPCEB13FG
    Intel Core i3-330M 2.13 GHz
    4 GB
    Intel HD media Accelerator
    Mozilla Firefox
Okay let me tell you my problem and the reason for updating in this thread.
I have a Windows 8 system. I am having issues connecting to internet(LAN cable).This was working fine a few days back. If I change the hard disk and connect a different hard disk which has Windows 7 it works perfectly fine. Notice the only thing changed here is the hard disk with different OS in it. This confirms that issue is not with the lan/ethernet cable/port.
I am currently seeing this message - "Ethernet 2 doesn't have a valid IP configuration".
When I checked the IP that's assigned this is what it says:
Autoconfiguration Ipv4 Address 169.254.31.190
Ipv4 Subnet Mask 255:255:0:0
Then i tried going to command prompt and gave
ipconfig /release
This wasn't of much help as it failed with some error message
Then I tried running sfc/scannow and dism /Online /Cleanup-Image /RestoreHealth looking at some of the posts posted here and online.
Running dism I am getting the same error as reported in this thread.
I have couple of questions:
1) Are these right steps to follow to fix this for internet connection issue ?
2) What do i need to get this valid ip configuration issue resolved ?
Note: There is no issue with the cable because i fixed another hard disk and booted and the internet was connecting there.
I don't have much idea in all this.I followed some of the things which were posted on net and checked.
Any help will be greatly appreciated.
    Intel i3-2100 @3.1 Ghz
    Intel HD graphics
    Benq G700
    Logitech mouse
