killerboye
I don't know, but I am also having problems with the same wireless network card. In Windows 8 everything was fine, but in 8.1 I get strange download speed drops when I speedtest it. My ping and upload speed is fine, but only the download speed is getting huge drops and sometimes is playing death, but I have no connection loses. I also tried all different drivers and no difference. Other computers are fine, but mine is not. I just think that the drivers aren't compatible with 8.1, but are for 8. Here on the windows page, Windows 8.1 compatibility for Asus PCE-N15 Wireless Network Adapter model they have no information about it, but some people also get same or different problems with the card, if you read below. I already send Asus a support message, so hopefully they will do something. The only 2 things you can do, is 1. use cable or 2. reïnstall 8 or lower.
I have many programs installed, so I am not going to reinstall it and if I am going to use a cable, I would need a 20m cable So temporary you can use the cable if you can move a table closer to the router.
Also what kind of wireless connection are you using? 802.11 b, g or n?
If you don't know: press ctrl+shift+esc then click on the tab on top "performance" then click on the left on "Wi-Fi", now you can see on the bottom what type of connection it is. (I am running 802.11g, because of my router).
Hopefully Asus responds with a message soon enough.
Here is my latest speedtest: Speedtest.net by Ookla - My Results
Download speed is just not stable, it sometimes gets even lower, normally I get 15+mbps atleast.
I hope someone else has a solution, because I already googled every possible way to find a solution.
Greetings killer.
Greetings killer.
- Windows 8.1 64-bit
- Computer type
- PC/Desktop
- CPU
- Intel i5 4670K
- Motherboard
- Gigabyte GA-Z87-HD3
- Memory
- Corsair Vengeance 8gb ddr3-1600 cl9 kit
- Graphics Card(s)
- Gigabyte GTX 760 OC 2GB
- Sound Card
- Monitor(s) Displays
- Acer G246HLBbid 24"
- Screen Resolution
- 1920x1080
- Hard Drives
- 1x WD10EZEX (1TB blue) HDD
1x M4-CT128M4SSD2 (128GB) SSD
- Case
- CM 690II Advanced
- Internet Speed
- 30/2
- Browser
- Google Chrome
- Antivirus
- Bitdefender Internet Security
