Windows 8.1 bsod problems mainly MEMORY_MANAGEMENT help!
I linked it right to the driver download page. All I can say is look better, I guess.
    7601.18247.x86fre.win7sp1
    Self-built Intel based
    Intel DQ965MT
    Hyundai 2 GB DDR2 @ 333 MHz
    Thermaltake 450W
    Logitech M510
    Optimum Online, fast for US
    Pale Moon
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
thanks for all the help with my problems i cant thank you enough im sorry if i was a bit stupid at some points anyway is there anything i need to do like give you best answer or something. i have been playing civ 5 all day and no bsod s all day :)
That's good stuff, glad to hear it. If you'd like, the start-shaped icon to the bottom left of posts (your theme may be different than the one I use) can give "Rep". Enjoy it.
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
nooooooooooooooooooooooooooooooooooooooooooooooooo:mad: i suppose i jinxed it i had a pfn list corrupt
heres the updated
grab all
When this actually gets updated, if crashes persist, use 667 MHz:
rtwlanu rtwlanu.sys Wed Dec 05 08:55:15 2012 (50BF5243)
Realtek
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
hi again as i was saying before that bsod i found out that the rtwlanu rtwlanu.sys is my wifi driver but i downloaded and installed new ones from tp-link yesterday ? i can also see that it is also located in "C:\Windows\WinSxS\amd64_netrtwlanu.inf_31bf3856ad364e35_6.3.9600.16384_none_96ff504c877c16d3\RTWlanU.sys" as i am not using the ethernet connection should i jusst uninstall the ethernet drivers from device manager because its located in amd 64 finally i have the boot disk and the product key could i just reinsatll windows
Why always such the aversion to following instructions and then instead, creating outlandish scenarios?
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
hi master chief sorry for being such a idiot could you just tell which drivers to download off the realtek site. is it just the first one on the link
RTL8188CUS
Driver Only Auto Installation Program (Support Win8.1)(Install Shield v1.00.0238)
1026.5.1118.2013
2014/1/15
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
Install using the Device Manager. Right click wireless. Update driver software. Browse my computer. Let me pick. Have disk. Browse. Double click on inf.
Scan for malware with Malwarebytes.
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
cant do it it says its not compatible with this os and i also had a another bluescreen so ill attach that aswell any ideas i ran a malware bytes quick scan and found no errors but when i try to run afull scan i get a bsod about 20 mins in
Again not follow instructions well?
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
i dont understand i did exactly what you said tried install using device manager then did a malware scan
Specifying a folder does not = "Double click on inf."
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
