In windows 7, windowed mode input lag was fixed by turning off aero. Is there a fix for windows 8?
- windows 8
Hi there
"Windowed Lag" -- not quite sure what you mean by that. Might be something as simple as a Wireless mouse not working properly.
I think in all the years of using computers I've never had a problem with "Windowed Lag" if it's what I think you mean - except years ago on something like Windows 2000 on an old CRT Monitor where the screen refresh rate was set too low and I could perceive some type of flickering.
If you've got even a modest NETBOOK with a horrible video chip in it the screen should be fine. Of course if you are using something like RDP - Remote desktop or logging in to a company VPN or some web sites then the speed will be dependant totally on the network and Internet connections.
Just ensure that your video drivers are up to date and perhaps set on 3D / hardware acceleration if these are available in your graphic settings.
Very unlikely but if you have a rubbish monitor that could cause problems too -- but that's so unlikely that I think you can safely ignore that scenario.
Cheers
jimbo
