This is all in the command prompt via the win 8 boot options "troubleshooting" menu.
I need not manually assign the Win 8 partition a drive letter here. The only time i ever did that,earlier in the thread, is in Win 7 because that hides the windows 8 partition. No need to do that manually anywhere else.
To answer your question, yes the directory structure is intact and sound. Seems to be no issue there, have run chkdsk and no errors too.
Here's what the bcdedit gives me. It does actually look correct here because if i browse the drives in the command prompt, D: is the Windows 7 partition and E: is the Win 8 partition. Again, slightly odd to me as thats not the configuration that i used to have in windows 8 when it worked and booted properly. But as far as this command prompt goes, what bcdedit tells me and how are the drives are configured DO match up.
Windows Boot Manager
identifier {bootmgr}
device partition=C:
description Windows Boot Manager
locale en-US
inherit {globalsettings}
integrityservices Enable
default {default}
resumeobject {aa157ba3-5eab-11e2-9c83-82293678c432}
displayorder {default}
{6cfb7b1e-be64-11e1-8152-8e2dbccb549a}
toolsdisplayorder {memdiag}
timeout 30
Windows Boot Loader
identifier {6cfb7b1e-be64-11e1-8152-8e2dbccb549a}
device partition=D:
path \Windows\system32\winload.exe
description Windows 7
locale en-US
inherit {bootloadersettings}
recoverysequence {6cfb7b1f-be64-11e1-8152-8e2dbccb549a}
recoveryenabled Yes
osdevice partition=D:
systemroot \Windows
resumeobject {6cfb7b1d-be64-11e1-8152-8e2dbccb549a}
nx OptIn
Windows Boot Loader
identifier {6cfb7b1f-be64-11e1-8152-8e2dbccb549a}
device ramdisk=[D:]\Recovery\6cfb7b1f-be64-11e1-8152-8e2dbccb549a\Winre.wim,{6cfb7b20-be64-11e1-8152-8e2dbccb549a}
path \windows\system32\winload.exe
description Windows Recovery Environment
osdevice ramdisk=[D:]\Recovery\6cfb7b1f-be64-11e1-8152-8e2dbccb549a\Winre.wim,{6cfb7b20-be64-11e1-8152-8e2dbccb549a}
systemroot \windows
nx OptIn
winpe Yes
Windows Boot Loader
identifier {current}
device ramdisk=[E:]\Recovery\6cfb7b23-be64-11e1-8152-8e2dbccb549a\Winre.wim,{6cfb7b24-be64-11e1-8152-8e2dbccb549a}
locale en-US
displaymessage Recovery
osdevice ramdisk=[E:]\Recovery\6cfb7b23-be64-11e1-8152-8e2dbccb549a\Winre.wim,{6cfb7b24-be64-11e1-8152-8e2dbccb549a}
systemroot \windows
nx OptIn
bootmenupolicy Standard
winpe Yes
Windows Boot Loader
identifier {default}
device partition=E:
description Windows 8
locale en-US
recoverysequence {current}
recoveryenabled Yes
allowedinmemorysettings 0x15000075
osdevice partition=E:
systemroot \Windows
nx OptIn
Resume from Hibernate
identifier {6cfb7b1d-be64-11e1-8152-8e2dbccb549a}
device partition=D:
path \Windows\system32\winresume.exe
description Windows Resume Application
locale en-US
inherit {resumeloadersettings}
filedevice partition=D:
filepath \hiberfil.sys
pae Yes
debugoptionenabled No
identifier {aa157ba3-5eab-11e2-9c83-82293678c432}
device partition=E:
locale en-US
recoveryenabled Yes
filedevice partition=E:
pae Yes
Windows Memory Tester
identifier {memdiag}
device partition=C:
path \boot\memtest.exe
description Windows Memory Diagnostic
locale en-US
badmemoryaccess Yes
EMS Settings
identifier {emssettings}
bootems No
Debugger Settings
identifier {dbgsettings}
debugtype Serial
debugport 1
baudrate 115200
RAM Defects
identifier {badmemory}
Global Settings
identifier {globalsettings}
inherit {dbgsettings}
{emssettings}
{badmemory}
Boot Loader Settings
identifier {bootloadersettings}
{hypervisorsettings}
Hypervisor Settings
identifier {hypervisorsettings}
hypervisordebugtype Serial
hypervisordebugport 1
hypervisorbaudrate 115200
Resume Loader Settings
identifier {resumeloadersettings}
Device options
identifier {6cfb7b20-be64-11e1-8152-8e2dbccb549a}
description Ramdisk Options
ramdisksdidevice partition=D:
ramdisksdipath \Recovery\6cfb7b1f-be64-11e1-8152-8e2dbccb549a\boot.sdi
Device options
identifier {6cfb7b24-be64-11e1-8152-8e2dbccb549a}
ramdisksdidevice partition=E:
ramdisksdipath \Recovery\6cfb7b23-be64-11e1-8152-8e2dbccb549a\boot.sdi
- Win 8 32bit
