Well, they have discovered that Li-ion batteries do suffer from memory effect too, but it is to such a lessor extent that is it not something we have to worry about. But you should, in fact, still fully discharge your Li-ion batteries every so often, but that is to re-calibrate the battery charge monitor circuits in the notebook.
Now of course notebooks do tend to be very proprietary because all the makers refused to agree on a standard Form Factor like they did with the ATX Form Factor for PCs. If they had, there would be a thriving build it yourself notebook industry like there is with PCs. They refused because there is more profit going proprietary, but also there is HUGE competition to make the thinnest and lightest notebooks with the longest battery run times.
Well, there are restrictions, but when it comes to RAM it is not to a specific brand. But in many cases, the chipset is only able to support certain size and speed RAM modules. So if the chipset supports up to 4GB sticks, you could not put an 8GB stick in there.The theory about newer systems (motherboard / BIOS) restricting upgrade options does sound convincing, though it turns out it's just another rumour.
- W10 Pro
- Computer type
- PC/Desktop
