MiniToolBox by Farbar Version: 01-07-2015
Ran by AminM (administrator) on 11-07-2015 at 13:42:12
Running from "C:\Users\AminM\Downloads\Programs"
Microsoft Windows 8.1 (X64)
Model: GS60 2PE Manufacturer: Micro-Star International Co., Ltd.
Boot Mode: Normal
========================= Flush DNS: ===================================
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
"Reset IE Proxy Settings": IE Proxy Settings were reset.
========================= Hosts content: =================================
========================= IP Configuration: ================================
Intel(R) Dual Band Wireless-AC 7260 = Wi-Fi (Connected)
Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) = Ethernet 2 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
set interface interface="Local Area Connection* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth Network Connection" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : AminM
DNS Suffix Search List. . . . . . : lan
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) #2
Physical Address. . . . . . . . . : 44-8A-5B-6F-A6-D4
Wireless LAN adapter Local Area Connection* 3:
Physical Address. . . . . . . . . : E8-2A-EA-A8-86-EA
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7260
Physical Address. . . . . . . . . : E8-2A-EA-A8-86-E9
Link-local IPv6 Address . . . . . : fe80::b121:7d29:f56c:72a5%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.103(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, July 11, 2015 1:23:37 PM
Lease Expires . . . . . . . . . . : Sunday, July 12, 2015 1:23:36 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 65546986
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-32-72-12-6C-62-6D-36-93-65
DNS Servers . . . . . . . . . . . : 192.168.1.1
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter Local Area Connection* 4:
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:1c84:329a:3f57:fe98(Preferred)
Link-local IPv6 Address . . . . . : fe80::1c84:329a:3f57:fe98%10(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 419430400
NetBIOS over Tcpip. . . . . . . . : Disabled
Server: dsldevice.lan
Address: 192.168.1.1
Addresses: 2a00:1450:4006:804::200e
216.58.210.238
Pinging google.com [216.58.210.238] with 32 bytes of data:
Reply from 216.58.210.238: bytes=32 time=90ms TTL=56
Reply from 216.58.210.238: bytes=32 time=89ms TTL=56
Ping statistics for 216.58.210.238:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 89ms, Maximum = 90ms, Average = 89ms
Addresses: 2001:4998:58:c02::a9
2001:4998:c:a06::2:4008
2001:4998:44:204::a7
98.139.183.24
98.138.253.109
206.190.36.45
Pinging yahoo.com [98.139.183.24] with 32 bytes of data:
Reply from 98.139.183.24: bytes=32 time=305ms TTL=45
Reply from 98.139.183.24: bytes=32 time=304ms TTL=45
Ping statistics for 98.139.183.24:
Minimum = 304ms, Maximum = 305ms, Average = 304ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
8...44 8a 5b 6f a6 d4 ......Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) #2
6...e8 2a ea a8 86 ea ......Microsoft Wi-Fi Direct Virtual Adapter
3...e8 2a ea a8 86 e9 ......Intel(R) Dual Band Wireless-AC 7260
1...........................Software Loopback Interface 1
9...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
10...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.103 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.103 281
192.168.1.103 255.255.255.255 On-link 192.168.1.103 281
192.168.1.255 255.255.255.255 On-link 192.168.1.103 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.103 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.103 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
10 306 ::/0 On-link
1 306 ::1/128 On-link
10 306 2001::/32 On-link
10 306 2001:0:5ef5:79fd:1c84:329a:3f57:fe98/128
On-link
3 281 fe80::/64 On-link
10 306 fe80::/64 On-link
10 306 fe80::1c84:329a:3f57:fe98/128
On-link
3 281 fe80::b121:7d29:f56c:72a5/128
On-link
1 306 ff00::/8 On-link
3 281 ff00::/8 On-link
10 306 ff00::/8 On-link
Persistent Routes:
None
========================= Winsock entries =====================================
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [55296] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [65536] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [23040] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [69120] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [88576] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [88576] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [30720] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (07/11/2015 00:55:20 PM) (Source: Microsoft-Windows-WMI) (User: NT AUTHORITY)
Description: Event provider ProtectionManagement attempted to register query "select * from MSFT_MpEvent" whose target class "MSFT_MpEvent" in //./root/microsoft/protectionManagement namespace does not exist. The query will be ignored.
Description: Event provider attempted to register query "select * from MSFT_MpEvent" whose target class "MSFT_MpEvent" in //./root/microsoft/protectionManagement namespace does not exist. The query will be ignored.
Error: (07/11/2015 10:31:09 AM) (Source: SideBySide) (User: )
Description: Activation context generation failed for "Microsoft.VC90.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"1".
Dependent Assembly Microsoft.VC90.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8" could not be found.
Please use sxstrace.exe for detailed diagnosis.
Error: (07/11/2015 09:41:53 AM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll8
Error: (07/11/2015 09:39:36 AM) (Source: Application Error) (User: )
Description: Faulting application name: devmonsrv.exe, version: 17.0.1403.430, time stamp: 0x52ef79d8
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0xb7362e98
Faulting process id: 0x7d8
Faulting application start time: 0xdevmonsrv.exe0
Faulting application path: devmonsrv.exe1
Faulting module path: devmonsrv.exe2
Report Id: devmonsrv.exe3
Faulting package full name: devmonsrv.exe4
Faulting package-relative application ID: devmonsrv.exe5
Error: (07/11/2015 09:37:32 AM) (Source: Application Error) (User: )
Description: Faulting application name: ChargeService.exe, version: 1.2.24.0, time stamp: 0x5306b3b0
Faulting module name: ChargeService.exe, version: 1.2.24.0, time stamp: 0x5306b3b0
Fault offset: 0x0000906d
Faulting process id: 0x660
Faulting application start time: 0xChargeService.exe0
Faulting application path: ChargeService.exe1
Faulting module path: ChargeService.exe2
Report Id: ChargeService.exe3
Faulting package full name: ChargeService.exe4
Faulting package-relative application ID: ChargeService.exe5
System errors:
Error: (07/11/2015 10:38:36 AM) (Source: DCOM) (User: AminM)
Description: {1B1F472E-3221-4826-97DB-2C2324D389AE}
Error: (07/11/2015 09:39:37 AM) (Source: Service Control Manager) (User: )
Description: The SSDP Discovery service failed to start due to the following error:
%%1069
Description: The SSDPSRV service was unable to log on as NT AUTHORITY\LocalService with the currently configured password due to the following error:
%%50
To ensure that the service is configured properly, use the Services snap-in in Microsoft Management Console (MMC).
Description: The Bluetooth OBEX Service service failed to start due to the following error:
%%109
Error: (07/11/2015 09:39:36 AM) (Source: DCOM) (User: NT AUTHORITY)
Description: {A47979D2-C419-11D9-A5B4-001185AD2B89}
Error: (07/11/2015 09:37:35 AM) (Source: Service Control Manager) (User: )
Description: The Network List Service service terminated with the following error:
%%21
Error: (07/11/2015 09:37:33 AM) (Source: Service Control Manager) (User: )
Description: The MSI_SuperCharger service terminated unexpectedly. It has done this 1 time(s).
Error: (07/11/2015 09:37:32 AM) (Source: Service Control Manager) (User: )
Description: The Intel(R) PROSet/Wireless Zero Configuration Service service terminated with the following error:
%%2147770990
Description: The IP Helper service terminated with the following error:
%%1058
Error: (06/24/2014 10:04:19 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Microsoft Office Sessions:
Error: (07/11/2015 00:55:20 PM) (Source: Microsoft-Windows-WMI)(User: NT AUTHORITY)
Description: ProtectionManagementselect * from MSFT_MpEventMSFT_MpEvent//./root/microsoft/protectionManagement
Description: select * from MSFT_MpEventMSFT_MpEvent//./root/microsoft/protectionManagement
Error: (07/11/2015 10:31:09 AM) (Source: SideBySide)(User: )
Description: Microsoft.VC90.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"C:\Program Files (x86)\Creative\Sound Blaster Cinema 2\Sound Blaster Cinema 2\CTMFPlay.dll
Error: (07/11/2015 09:41:53 AM) (Source: Perflib)(User: )
Error: (07/11/2015 09:39:36 AM) (Source: Application Error)(User: )
Description: devmonsrv.exe17.0.1403.43052ef79d8unknown0.0.0.000000000c0000005b7362e987d801d0bba45ad23a07C:\Program Files (x86)\Intel\Bluetooth\devmonsrv.exeunknown989b60a6-2797-11e5-8263-448a5b6fa6d4
Error: (07/11/2015 09:37:32 AM) (Source: Application Error)(User: )
Description: ChargeService.exe1.2.24.05306b3b0ChargeService.exe1.2.24.05306b3b0c00000050000906d66001d0bba410c6bb7aC:\Program Files (x86)\MSI\SUPER CHARGER\ChargeService.exeC:\Program Files (x86)\MSI\SUPER CHARGER\ChargeService.exe4eaee239-2797-11e5-8263-e82aeaa886ed
=========================== Installed Programs ============================
Battery Calibration (HKLM-x32\...\{619FA785-489B-4D22-911F-82D6EDF5BDB0}) (Version: 1.0.1405.0701 - Micro-Star International Co., Ltd.)
Boot Configure (HKLM-x32\...\{AB72B3BB-A389-4F62-86EE-C08326B4BE60}) (Version: 20.014.05233 - Micro-Star International Co., Ltd.)
BurnRecovery (HKLM-x32\...\{2892E1B7-E24D-4CCB-B8A7-B63D4B66F89F}) (Version: 4.0.1402.2601 - )
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
Dragon Gaming Center (HKLM-x32\...\{965B16C7-0778-4C45-B7D1-83A59E6FBBCB}) (Version: 1.0.1405.1201 - Micro-Star International Co., Ltd.) Hidden
Dragon Gaming Center (HKLM-x32\...\InstallShield_{965B16C7-0778-4C45-B7D1-83A59E6FBBCB}) (Version: 1.0.1405.1201 - Micro-Star International Co., Ltd.)
ETDWare PS/2-X64 11.13.7.5_WHQL (HKLM\...\Elantech) (Version: 11.13.7.5 - ELAN Microelectronic Corp.)
Fotogalerie (HKLM-x32\...\{56018684-241C-4D81-A4F6-CED1B5292C49}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Galeria de Fotos (HKLM-x32\...\{5984647D-06D5-4D4A-A5F9-1566F3846FE7}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Galería de fotos (HKLM-x32\...\{5AE1297A-58E3-40F2-9C59-ADCB8CF56918}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Galerie de photos (HKLM-x32\...\{43711B8E-AE78-4C83-84EC-3E86D689311C}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 43.0.2357.132 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.27.5 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.21.115 - Google Inc.) Hidden
Intel(R) Driver Update Utility 2.0 (HKLM-x32\...\{59DB38EB-F864-4E10-841D-38CFBCF864B0}) (Version: 2.0.0.29 - Intel) Hidden
Intel(R) Manageability Engine Firmware Recovery Agent (HKLM-x32\...\{0EC7F9CC-4741-45AE-9F55-6E9343F726F5}) (Version: 1.1.0.36960 - Intel Corporation)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.23.1766 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.14.4170 - Intel Corporation)
Intel(R) PROSet/Wireless Software for Bluetooth(R) Technology(patch version 17.0.1414.3) (HKLM\...\{302600C1-6BDF-4FD1-1403-148929CC1385}) (Version: 17.0.1403.0442 - Intel Corporation)
Intel(R) Rapid Storage Technology (HKLM\...\{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 12.9.0.1001 - Intel Corporation)
Intel® Driver Update Utility (HKLM-x32\...\{8409c4f7-2340-4933-a304-5d37db4fb48b}) (Version: 2.0.0.29 - Intel)
Intel® PROSet/Wireless Software (HKLM-x32\...\{21de8cfa-6d1e-4bb2-bbe2-0bc64e82d547}) (Version: 17.0.3 - Intel Corporation)
Internet Download Manager (HKLM-x32\...\Internet Download Manager) (Version: - Tonec Inc.)
KB9X Radio Switch Driver (HKLM\...\5AADE1068CF70DD983F763B20CF2CAAB72883915) (Version: 1.1.0.0 - ENE TECHNOLOGY INC.)
MAGIX MX Suite (HKLM\...\{43136332-880B-458A-966C-900C18752B66}) (Version: 1.13.0.121 - MAGIX AG) Hidden
MAGIX MX Suite (HKLM-x32\...\MAGIX_{43136332-880B-458A-966C-900C18752B66}) (Version: 1.13.0.121 - MAGIX AG)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Office (HKLM-x32\...\{90150000-0138-0409-0000-0000000FF1CE}) (Version: 15.0.4569.1506 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.40416.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 (HKLM\...\{1D8E6291-B0D5-35EC-8441-6616F567A0F7}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Movie Maker (HKLM-x32\...\{186312F7-5E94-4709-859E-8A91F97DC674}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{1CE02F72-FB6B-4045-A275-E8DC3CF43879}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{5A88AF74-251F-4CE1-A9C4-5A627D10AE16}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{5AB7E6E6-6A01-4358-8215-9BC98583D83F}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{6B8F6950-F0C4-4A61-B255-B957B5EF46D9}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{83ABE916-759A-49BE-BCEB-91F237E01502}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{841DEFC2-5D78-43D2-9B21-BDC0799D462B}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{8C22A294-DBBA-445F-B55C-E26817CCFE69}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{C313F37C-71DB-4272-ADCE-E7CF7E3C8D87}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{C40A1FAD-DBB0-4A8C-8263-2A7B74E4520A}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{C95AEB53-7FAE-4257-97AF-7136E8D9F9CA}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{D508605F-300D-42A4-B288-FC1D2E29158D}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DCA6C9A9-D593-4BF3-9AD2-C1AA69DFAB27}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
MSI Remind Manager (HKLM-x32\...\{3E23F267-3E35-40F9-B6BF-BC034D214717}) (Version: 1.0.1404.1101 - Micro-Star International Co., Ltd.) Hidden
MSI Remind Manager (HKLM-x32\...\InstallShield_{3E23F267-3E35-40F9-B6BF-BC034D214717}) (Version: 1.0.1404.1101 - Micro-Star International Co., Ltd.)
MSI Social Media Collection (HKLM-x32\...\{7ADEC426-BE95-48EF-84D4-086BD0F4D331}) (Version: 1.14.2251 - Micro-Star International Co., Ltd.)
Norton Anti-Theft (HKLM-x32\...\NAT) (Version: 1.9.0.14 - Symantec Corporation)
Norton Internet Security (HKLM-x32\...\NIS) (Version: 21.6.0.32 - Symantec Corporation)
Norton Online Backup (HKLM-x32\...\{E625FCA0-E43E-4D3B-92FF-4851308A0366}) (Version: 2.8.0.44 - Symantec Corporation)
Norton Online Backup (HKLM-x32\...\NARA) (Version: 4.5.0.9 - Symantec Corporation) Hidden
NVIDIA GeForce Experience 2.4.5.57 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 2.4.5.57 - NVIDIA Corporation)
NVIDIA Graphics Driver 353.30 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 353.30 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.15.0428 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.15.0428 - NVIDIA Corporation)
Qualcomm Atheros Bandwidth Control Filter Driver (HKLM\...\{CCD797F1-171F-4B3A-BD30-4F59F653E1A0}) (Version: 1.1.42.1045 - Qualcomm Atheros) Hidden
Qualcomm Atheros Killer E220x Drivers (HKLM\...\{F45761DC-2470-47FF-9E9B-F4016568C29A}) (Version: 1.1.42.1045 - Qualcomm Atheros) Hidden
Qualcomm Atheros Network Manager (HKLM\...\{4692B750-DE88-4DCF-9163-745AF5604B24}) (Version: 1.1.42.1045 - Qualcomm Atheros) Hidden
Qualcomm Atheros Performance Suite (HKLM-x32\...\{E70DB50B-10B4-46BC-9DE2-AB8B49E061EE}) (Version: 1.1.42.1045 - Qualcomm Atheros)
Realtek Card Reader (HKLM-x32\...\{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.3.9600.21249 - Realtek Semiconductor Corp.)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7240 - Realtek Semiconductor Corp.)
SCM (HKLM\...\{6692DCAF-A445-4C6B-AF31-3DD85FC06FBA}) (Version: 13.014.01026 - Application)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 4.1.2000 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 2.4.5.57 - NVIDIA Corporation) Hidden
Sizing Options (HKLM-x32\...\{DFAB6DE8-E45F-4D5D-95C0-E54C58993F9F}) (Version: 1.0.1401.1001 - Application) Hidden
Sizing Options (HKLM-x32\...\InstallShield_{DFAB6DE8-E45F-4D5D-95C0-E54C58993F9F}) (Version: 1.0.1401.1001 - Application)
Skype™ 7.3 (HKLM-x32\...\{24991BA0-F0EE-44AD-9CC8-5EC50AECF6B7}) (Version: 7.3.101 - Skype Technologies S.A.)
Sound Blaster Cinema 2 (HKLM-x32\...\{B4F6F8CC-2C61-42CC-A4CC-76621F25BDC7}) (Version: 1.00.05 - Creative Technology Limited)
SteelSeries Engine (HKLM\...\SteelSeries Engine) (Version: 2.8.445.23476 - SteelSeries)
SUPER CHARGER (HKLM-x32\...\{7CDF10DD-A9B5-4DA3-AB95-E193248D4369}_is1) (Version: 1.2.024 - MSI)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3522.0110 - Microsoft Corporation)
WinZip 17.5 (HKLM\...\{CD95F661-A5C4-44F5-A6AA-ECDD91C240DD}) (Version: 17.5.10562 - WinZip Computing, S.L. )
XSplit Gamecaster (HKLM-x32\...\{13DCC429-29D0-48CF-8C68-A7196980A298}) (Version: 1.6.1404.2104 - SplitmediaLabs)
??? ????? (HKLM-x32\...\{464847E7-6960-407E-A710-8AC3B1D448E3}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
???? ????? (HKLM-x32\...\{8CDC81A6-1453-42CA-AA6F-909EF7363F21}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
?? ??? (HKLM-x32\...\{D8A7062C-87C1-48D4-8D11-FAF6D5167BA2}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
???? (HKLM-x32\...\{B56ADA3D-7E16-447C-AAC6-1E1EBEDEC505}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
??? (HKLM-x32\...\{408995B7-AAAE-4972-B60E-4C0E086A3952}) (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
========================= Devices: ================================
========================= Memory info: ===================================
Percentage of memory in use: 22%
Total physical RAM: 16303.02 MB
Available physical RAM: 12675.13 MB
Total Virtual: 19247.02 MB
Available Virtual: 15713.93 MB
========================= Partitions: =====================================
1 Drive c: (OS_Install) (Fixed) (Total:118.24 GB) (Free:54.47 GB) NTFS
2 Drive d: (Data) (Fixed) (Total:916.46 GB) (Free:775.64 GB) NTFS
========================= Users: ========================================
User accounts for \\AMINM
Administrator AminM Guest
========================= Minidump Files ==================================
No minidump file found
========================= Restore Points ==================================
11-07-2015 07:23:08 Removed NVIDIA PhysX
**** End of log ****
