Wifi Auto-Connect to two-wifi APs, problem
CarvedDuck
Hi All,
Win8:
I have two wifi APs in the home and I have it all set up so that one is the Internet by cell phone tether and the other is the cabled network via the router wifi.
Works just fine - except.
On wifi 1, Internet I have it set for "Connect automatically" which at boot up it does.
On wifi 2, Network I also have it set for "Connect automatically" which at boot up it does NOT do. I have to go in and connect manually even though the "Connect automatically" is checked.
It seems win8 sees "Connect automatically"and does it but then stops checking other connections. Probably a "feature." :)
Is there some way to force both "Connect automatically" to happen?
Thanks
    win8.1
    Acer V5
    i5
    6GB
    240GB Sandisk SSD
    4G/LTE
There is a group policy setting for this, but even if both are connected you will only be using one of those connections at a time.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Thanks, I explained that poorly. As well as two APs I also have extra wifi adapters on the PCs I need to access both Internet and LAN without plugging into the LAN. I have since made it work and both wifi are connected. I started out with the information on site linked below, then went from there.
This link describes for setting up a single wifi, but I duplicated the process for the second adapter.
win8. Can't automatically connect to Wifi? Solved | Firebird - VB.net
So, now I have it working for the win8 machine but the win7 still needs some work as it is only connecting to one at a time even though there are two different wifi channels available and the Group Policy has been set.
    win8.1
    Acer V5
    i5
    6GB
    240GB Sandisk SSD
    4G/LTE
Considering the link you posted shows a wired connection I now have no idea what this post is about but the Group Policy setting does allow Windows to pick up multiple connection at start up.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
