Why is my wireless slower than my wired connection?
alkaufmann
I just installed a new wireless ac adapter and I do get a 1.3Gbps connection to my router. However when I test this connection by transferring some large files I get about 350Mbps for sending and 600 Mbps for receiving. When I transfer the same files with a 1Gbps wired connection I get about 970Mbps for sending (I think that includes some caching) and 760 Mbps for receiving.
Are there some options in Windows 8.1 Pro that can be set to get better wireless performance?
    Windows 8.1 Pro WMC
    Masuhr - Black Corsair
    Intel I7 4770k
    ASUS Maximus VI Hero
    Corsair Dominator 16GB DD3-1866
    Asus GTX 660 Ti
    ASUS PA248
    1920x1200
    Revodrive 350 480GB
    SSD Mushkin Chronos Deluxe 240GB Sata3
    HDD WD Red 2x2TB Sata3
    Corsair 860i
    Cooler Master HAF X
    Corsair H100i
    LG G19
    Microsoft Sidewinder X8
    DSL
    IE
    MS Defender
    Logitech T650 Touchpad
You may get a much better explanation than mine but a wireless connection generally has overhead because of the need for encryption. From my experience wired has always been (at least a bit) faster than wireless. I wish I had your problems.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Yes these slow wireless connections are simply terrible. ;)
No magic button fix or real options for this although I would expect the wireless to be a bit slower and even with the 1.3GB speeds you still might need to get through another A/P or switch at 1GB.
You might try working with the advanced settings for the wireless AC NIC in Device Manger.
I think that actual throughput is supposed to be closer to 480Mbps even with a wired connection but it looks like a bit faster is possible from what the Op posted. Maybe I should measure this on my network.
Typically with wireless you would get maybe 1/2 the actual throughput compared to what the status is showing.
Maybe you can find more answers in the link which talks about wireless ac and it's potential.
In perfect conditions, close to the access point, a three-stream 11ac radio can achieve the maximum raw data rate of 1.3Gbps. But no users will actually realize that in terms of useable throughput. "Typically, if the client is close to the access point, you can expect to lose about 40% of the overall raw bit rate due to protocol overhead acknowledgements, setup, beaconing and so on,"
802.11ac 'gigabit Wi-Fi' starts to show potential, limits - Computerworld
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Change the channel if you are in a crowded wireless zone
    Windows 8, Kali
    HP ENVY TouchSmart m6 Sleekbook
    i5 4200 u
    8gb DDR3 1600
    Intel HD 4400
    Defender
Thanks, I did forget that the wireless connection requires security which may slow things down.
    Windows 8.1 Pro WMC
    Intel I7 4770k
    Asus GTX 660 Ti
    ASUS PA248
    1920x1200
    Revodrive 350 480GB
    Corsair 860i
    Cooler Master HAF X
    Corsair H100i
    LG G19
    DSL
    IE
    MS Defender
I did look at that and there are a ton of options there. I will start to look for a thread on how these options should be set, Asus provides no information.
When transferring large files from one computer to another with a wired connection I can get very high speeds and the network utilization is greater than 90%. What I find strange is the transferring the file from one hard drive to another in the same machine is slower. :shock:
I have moved that machine so that the signal travels through a couple of walls and the connection has dropped to around 877.5 Mbps to 1Gbps. When I transferred a bunch of files the average speed was 350Mbps and network utilization approx. 37%.
Thanks for that link.
    Windows 8.1 Pro WMC
    Intel I7 4770k
    Asus GTX 660 Ti
    ASUS PA248
    1920x1200
    Revodrive 350 480GB
    Corsair 860i
    Cooler Master HAF X
    Corsair H100i
    LG G19
    DSL
    IE
    MS Defender
Live in an apartment building surrounded by other apartments buildings and my system can see a lot of wireless connections but none in the 5Ghz range. I will try some different channels and disable everything but the ac connection and see if that changes anything for me.
    Windows 8.1 Pro WMC
    Intel I7 4770k
    Asus GTX 660 Ti
    ASUS PA248
    1920x1200
    Revodrive 350 480GB
    Corsair 860i
    Cooler Master HAF X
    Corsair H100i
    LG G19
    DSL
    IE
    MS Defender
I'm honestly surprised that you can achieve 877.5Mbps going through a couple walls with 5Ghz frequency which typically doesn't go through walls worth a darn, at least that is how it works for me and everyone else, many complaints about this although the 2.4Ghz frequency has no problems with a few walls.
I get the same 877.5Mbps but my access point "Asus AC66U" is mounted outside my house under the eves while the client is 35 feet away across my yard with only a few palm trees in the way.
Still it's a very fast connection and HD streaming works great and I can run multiple YouTube vid's without problems.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
