My PC specs: Asus P8Z77-V with a SATA2 WD Caviar Black 500GB. The HDD has three partitions, and I've had Windows 7 32 bit installed on C:/ for three years.
Before installation, the BIOS has Secure Boot and CSM enabled.
Yesterday, I cut D: into two partitions, and use the second to install Windows 8.1 64-bit through a DVD. The installation went perfectly fine, and the new OS works wonder. The partitions now look like this (all primary, C is active):
C:/Windows 7 <> D:/Stuffs <> E:/Windows 8 <> F:/Stuffs
However, whenever I try to boot into Windows 7, I always receive an Windows Boot Manager error of "0xc000000f A required device isn't connected or can't be accessed".
- First thing I done was popping in a W7 repair disc, however no problems were reported.
- Then I disabled fast startup in W8, however it still uses the hiberfi.sys file.
- I started msconfig in W8, and choose W7 as the default OS. Nothing changed.
- Disabled Secure Boot and enable CSM to support both UEFI & Legacy in BIOS. Nothing changed.
- Aligned partitions and rebuilt MBR in partition wizards. Nothing changed.
I give up. I have tried every option possible. The only fix options I found left was winload.exe, bcdedit or using easybcd. I'm going to give it a shot but can't guarantee how will it turn out. Should anyone help me with this specific problem, I'd be greatly appreciated. Thanks for reading.
- Windows 7 32bit & Windows 8.1 64 bit
- Computer type
- PC/Desktop
- CPU
- Intel Core i5-3350p
- Motherboard
- Asus P8Z77-V
- Graphics Card(s)
- Asus GTS 450 Direct CU II
- Monitor(s) Displays
- Acer G195HQL
- Screen Resolution
- 1400x900
- Hard Drives
- Caviar Black 500GB
- Keyboard
- Tt Esports Challenger Pro
