Solved using my cpu without thermal paste totally no (Fan) too
In my 25 years of build and repairing PC's, in the past 10 years or so, I have never seen a CPU "burn up" for any reason. The modern CPU's have a thermal overload built in so if the temps exceed the mas temp allowed, the CPU will simply shut down and not boot up again until it cools down. I don't recommend testing this on a CPU that you need because I don't know what the long term results of such "stress testing" on the CPU would be but CPU's do not simply "burn up" like they used to many years ago.... I hooked up a Q6600 CPU yesterday and forgot to plug in the cPU fan to the motherboard and it booted into the BIOS then ran for a minute or two then shut down. No harm done...
The shutdown was possible triggered by the BIOS-Settings: Click
Thermal Management for Intel® Core™2 Family Desktop Processors
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
