Updating window, do not power down! Can I power down ?
MSWINUSER
I have WIN 7 and WIN 8 with automatic updates turned on as recommended by MS. It is very annoying when you want to shut down and go in a hurry, you see this message saying 1 of xx updates, do not power down.... You don't normally shut down unless you want to go and this is delaying you from doing so. Can I just power down if I really need to go and can not wait ?
    win 8 pro
    DELL
    i5
    6g
    intel
I avoid that issue by setting Windows Update so it will check for updates but let me choose when
to download and install them. Then I can install them whenever it's convenient to do so.
http://www.eightforums.com/tutorial...-automatic-updating-turn-off-windows-8-a.html
Doing it this way also lets you choose to reject individual updates if they prove to cause issues for
you, and can assist in finding and isolating/hiding any 'bad' updates.
If your computer has Sleep mode enabled, you may be able to just let it go, and it will install the
updates and either reboot then go to sleep, or pop a box up asking you to restart, then simply go
to sleep till you return, but I have not tried this, so can't say whether it will work or not.
Hope this helps you.
Wenda.
    Windows 8.1 'Ultimate' RTM 64 bit (Pro/WMC).
    Acer AS8951G 'Desktop Replacement'.
    i7-2670QM@2.2/3.1Ghz.
    Acer
    8GB@1366Mhz.
    GeForce GT555M 2GB DDR3
    Realtek HD w/Dolby 5.1 surround.
    Built-in. Non-touch.
    18/4" 1920x1080 full-HD.
    Toshiba 750GBx2 internal. 1x2TB, 2x640GB, 1x500GB external.
    Stock.
    Laptop.
    Stock.
    Full 101-key
    USB cordless.
    IE11, Firefox, Tor.
    Windows Defender, MalwareBytes Pro.
    BD-ROM drive.
I agree with Wenda. If it's an issue, you may want to consider setting it up to be more manual. Powering down in the middle of the update may or may not cause you to scrog your system, depending upon where it is in the process. I would not chance it.
    Win 7 / Win 8
    Lenovo T510 / HP ProBook 4540S
    Intel i5-510m / Intel i3-3110m
    4GB / 8GB
    15.6"
Why do you feel like you have to wait for it? It will shut off automatically, why not just leave?
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
