Sound Popping/Crackling
I connected both mobo connections to psu and im not using graphic card to repair this. I also used another exact same psu from my bro's computer and same result it did not boot. I don't think it's CPU since Prime95 did not display any errors. So I'm guessing mobo? It's kinda weird.
EDIT: Yeah it's not my PSU for sure.
    Its home built MOFO!
    i5 3570k
    P8Z77-M
    2x4GB 1600
    Triple Fan Windorce Gigabyte 670 Factory OC
    Asus Xonar DX
    2x 24 in. -- 1x60hz[3ms] 1x144hz[1ms]
    3840x1080
    1 x samsung 840 120gb
    2 x 500gb 7200rpm
    XFX PRO 850w
    Fractal mid case i dont rembr
    Corsair H100
    CMstorm quickfire
    Razer Mamba (latest) + Logitech G500
    20mb down and 2.5 up
    Chrome
    beyerdynamic MMX 300 Headset (check em out)
So basically I am going to buy a new mobo and send this one for warranty. But could it be something else? such as the ram ?
I tested the CPU in a different computer and it worked.
    i5 3570k
    P8Z77-M
    2x4GB 1600
    Asus Xonar DX
    3840x1080
    2 x 500gb 7200rpm
    XFX PRO 850w
    Corsair H100
    CMstorm quickfire
    Chrome
So I bought a new mobo, now my computer boots. But to my horror the crackling is still there. Confused...
    i5 3570k
    P8Z77-M
    2x4GB 1600
    Asus Xonar DX
    3840x1080
    2 x 500gb 7200rpm
    XFX PRO 850w
    Corsair H100
    CMstorm quickfire
    Chrome
Did you do a complete new install with the new motherboard?
Your sound issue, although others have had the problem, seems to be more unique to your installation. You have changed the motherboard and still have the problem. It now goes back to application software or some other hardware attached device, or even something external to the PC. Does this do it on ANY sound? or is it only on certain applications such as the COD? If play a commercial audio CD do you get the noise?
This is crazy. I can even hear it a tiny bit on other computers.
I hear it pretty much when a windows sound or little sounds starts or ends. I also hear it at loud frequencies when people are loud on Ventrilo.
Basically, I spam the windows sound volume adjuster and it pops.
Way more than my friends computer.
And yes I have made a fresh install + tried another windows 8 ssd from another case.
I also tried different mouse/keyboard and different cpu+psu.
I basically made a different computer and the problem occurred.
When I play music it does sound awesome with my xonar dx + mmx 300
The new Sabertooth mobo is not micro so I'm going to have to get a new case but I'm out of cash and I got fired. :S
    i5 3570k
    P8Z77-M
    2x4GB 1600
    Asus Xonar DX
    3840x1080
    2 x 500gb 7200rpm
    XFX PRO 850w
    Corsair H100
    CMstorm quickfire
    Chrome
