Vendor : Qualcomm Atheros Communications Inc.
Provider : Qualcomm Atheros Communications Inc.
Date : 3/25/2014
Version : 10.0.0.287
INF file : C:\Windows\INF\oem11.inf
Files : 2 total
C:\Windows\system32\DRIVERS\athw8x.sys
C:\Windows\system32\drivers\vwifibus.sys
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Personal TKIP
WPA2-Enterprise TKIP
WPA2-Personal TKIP
Vendor defined TKIP
WPA2-Enterprise Vendor defined
Vendor defined Vendor defined
WPA-Enterprise CCMP
WPA-Personal CCMP
WPA2-Enterprise CCMP
Vendor defined CCMP
WPA2-Personal CCMP
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA2-Personal CCMP
============================= SHOW INTERFACES =========================
There is 1 interface on the system:
Description : Qualcomm Atheros AR956x Wireless Network Adapter
GUID : 47bcedb6-c183-442f-ac00-d4c7cbf14c32
Physical address : 64:5a:04:39:1f:9a
State : connected
SSID : TEO-187610
BSSID : 00:8c:54:57:92:54
Network type : Infrastructure
Radio type : 802.11n
Authentication : WPA2-Personal
Cipher : CCMP
Connection mode : Auto Connect
Channel : 11
Receive rate (Mbps) : 72.2
Transmit rate (Mbps) : 72.2
Signal : 100%
Profile : TEO-187610
Hosted network status : Not started
=========================== SHOW HOSTED NETWORK =======================
Status : Not started
============================= SHOW SETTINGS ===========================
Wireless LAN settings
Show blocked networks in visible network list: No
Only use GP profiles on GP-configured networks: No
Hosted network mode allowed in WLAN service: Yes
Allow shared user credentials for network authentication: Yes
Block period: Not Configured.
Auto configuration logic is enabled on interface "Wi-Fi"
============================== SHOW FILTERS ===========================
Allow list on the system (group policy)
<None>
Allow list on the system (user)
<None>
Block list on the system (group policy)
<None>
Block list on the system (user)
<None>
=========================== SHOW CREATEALLUSER ========================
Everyone is allowed to create all user profiles.
============================= SHOW PROFILES ===========================
Profiles on interface Wi-Fi:
Group policy profiles (read only)
<None>
User profiles
All User Profile : TEO-187610
========================== SHOW PROFILES NAME=* =======================
Profile TEO-187610 on interface Wi-Fi:
Applied: All User Profile
Profile information
Version : 1
Type : Wireless LAN
Control options :
Connection mode : Connect automatically
Network broadcast : Connect only if this network is broadcasting
AutoSwitch : Do not switch to other networks
Connectivity settings
Number of SSIDs : 1
SSID name : "TEO-187610"
Radio type : [ Any Radio Type ]
Vendor extension : Not present
Cost settings
Cost : Unrestricted
Congested : No
Approaching Data Limit : No
Over Data Limit : No
Roaming : No
Cost Source : Default
======================= SHOW NETWORKS MODE=BSSID ======================
Interface name : Wi-Fi
There are 6 networks currently visible.
SSID 1 : TEO-9C58D9
Authentication : WPA-Personal
Encryption : TKIP
BSSID 1 : 38:22:9d:33:07:78
Signal : 96%
Radio type : 802.11g
Channel : 1
Basic rates (Mbps) : 1 2 5.5 11
Other rates (Mbps) : 6 9 12 18 24 36 48 54
SSID 2 : rugiles
Encryption : CCMP
BSSID 1 : f8:d1:11:bb:25:70
Signal : 46%
Channel : 1
SSID 3 : TEO-723252
Encryption : CCMP
BSSID 1 : d4:d1:84:f6:22:b0
Signal : 66%
Channel : 6
SSID 4 : TEO-878341
Encryption : CCMP
BSSID 1 : dc:0b:1a:d0:99:41
Signal : 90%
Channel : 6
SSID 5 : TEO-187610
Encryption : CCMP
BSSID 1 : 00:8c:54:57:92:54
Signal : 100%
Channel : 11
SSID 6 : rotuse
Encryption : TKIP
BSSID 1 : 00:22:33:f0:4b:c6
Signal : 68%
Channel : 10
Basic rates (Mbps) : 1 2 5.5 6 11 12 24
Other rates (Mbps) : 9 18 36 48 54
I don't think this is a modem or router problem, i think that is a laptop drivers, becouse when i reinstall drivers i get good speed and after restaring the laptop it goes back to slow speed, maybe my laptop delete some drivers when restarting or smth? i updated my drivers to the latest version.
Try setting your channel to 1. If the Gateway is Wireless-N capable and allows for Dual channels. Set it for 40mhz, if you have no Wireless-b/g devices on your wifi network. Set secondary channel for Upper. You could always just turn off wifi on the ISP supplied gateway and use your own Wireless-N A/P.
I have had no problems using the Engenius ECB-350 A/P. It puts out enough power, that I can cover the downstairs and the whole upstairs, along with about 75' from the house for wifi coverage.
