Solved sfc /scannow issue
thanks a lot KYHI, I really like your magic tool.
the issue was solved here
https://www.sysnative.com/forums/wi...avast-causing-corrupt-manifest-files-fix.html
SFCFix script
  1. Download SFCFix.exe (by niemiro) and save this to your Desktop.
  2. Go to your desktop and right click on the background -> Select New -> Text Document -> Name this file SFCFixScript.txt.
  3. Open up SFCFixScript.txt and copy all of the following text inside the code box below and paste it into SFCFixScript.txt.
    [HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_avast.vc110.crt_2036b14a11e83e4a_11.0.60610.1_none_d58a6d64ab65b396]
    "S256H"=hex:7B,77,F2,78,0D,21,C3,A7,CF,3C,6A,E3,2D,31,A7,C4,6C,21,7E,AE,32,1E,89,7C,22,D5,C4,F2,9F,34,67,5D
    [HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_avast.vc110.crt_2036b14a11e83e4a_11.0.60610.1_none_1d37a43bbfe1dc9c]
    "S256H"=hex:63,A7,68,7E,FF,CA,7B,E2,C7,B0,57,DF,F4,8B,F1,39,19,DE,61,49,57,85,1D,8D,92,70,A2,B0,17,B0,9A,75
  4. Click on File -> Save. Close out of SFCFixScript.txt.
  5. Save any open documents and close all open windows.
  6. On your Desktop, you should see two files: SFCFix.exe and SFCFixScript.txt.
  7. Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it.
  8. SFCFix will now process the script.
  9. Upon completion, a file should be created on your Desktop: SFCFix.txt.
  10. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
    tags around the log to break up the text.
SFC /SCANNOW
  1. Right click on the
    button
  2. Click on Command prompt (Admin) => Press Yes on the prompt
  3. Inside the Command Prompt windows copy and paste the following command SFC /SCANNOW
  4. Please wait for this to Finish before continuing with rest of the steps
    Windows 8.1 64bit (6,3 Build 9600)
    Sony VAIO SVE1512A4E
    Intel(R) Pentium(R) CPU B980 @2.40GHz 2.40GHz
    4,00 Go
    Intel Corporation Intel HD Graphics
    Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller
    Monitor Plug-and-Play générique
    1366x768
    Harddrive ST640LM001HN-M640MBB from 596.17 GB SATA II
    Avast! INTERNET SECURITY
