Solved Problem with Radio Shortcut Addresses
I think that will work.
I 'tested' the scenario in a virtual machine using Windows Media Player. Technology still got in the way - my audio did not work in the VM and WMP complained, but
The Internet shortcut did launch WMP which still complained about the audio.
1) Bookmark this page
name it mms-b
2) Open bookmarks
Right click the bookmark mms-b created in step 1
select properties from the context menu (at the bottom of the list)
paste any of the addresses you want to listen to in a stream into the URL [______] textbox
Click OK
3) Double click the mms-b bookmark you just modified
It might take a while to begin streaming, give it a few minutes
4) Leave it in your bookmarks or copy it to your desktop
Double click the copy of mms-b on your desktop to test it in that location.
That's the best I could do, I hope it helps with the issue.
Here are the URLs from your posts:
mms://a1477.l3760635476.c37606.n.lm.akamaistream.net/D/1477/37606/v0001/reflector:35476
mms://50.22.223.13/s_gmd
mms://50.22.223.13/afs
mms://50.22.223.13/frs_a​
Bill
    Win8.1 Pro | Win10TP Pro - boot to VHD
    HP Pavilion dv6-c610us
    AMD VISION A6-3420M Quad-Core (2.4GHz/1.5GHz)
    HP
    6GB DDR3 SDRAM (2 DIMM)
    AMD Radeon HD 6520G Discrete-Class Graphics
    HP 2072a (20" LED)
    1600 x 900
    Hitachi 640GB (5400 RPM)
    Seagate 2 TB external
    WD 500 GB external
    Logitech K520 (wireless bundle)
    Logitech M310 (wireless bundle)
    IE 11 (default) & Pale Moon
    HP product specs:
    http://support.hp.com/us-en/product/HP-Pavilion-dv6-6c00-Entertainment-Notebook-PC-series/5191856/model/5218495/document/c03138553/
the problem is still the same
    Windows 8.1 64bit (6,3 Build 9600)
    Sony VAIO SVE1512A4E
    Intel(R) Pentium(R) CPU B980 @2.40GHz 2.40GHz
    4,00 Go
    Intel Corporation Intel HD Graphics
    Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller
    Monitor Plug-and-Play générique
    1366x768
    Harddrive ST640LM001HN-M640MBB from 596.17 GB SATA II
    Avast! INTERNET SECURITY
Can you play this---
test---It should cause a download of the radio player that will play in wmp---
http://www.jmu.edu/wmra/wemc.m3u
A picture---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
this one works for me!
    4,00 Go
    1366x768
I tried the radio shortcuts that won't work for me on another computer and they worked normally without any problem!
    4,00 Go
    1366x768
the extension of the ones I have is '.url' and the one you've just given me is '.w3u'
    4,00 Go
    1366x768
Try downloading and unzipping this shortcut: View attachment mmms-b.zip
It has the mms://50.22.223.13/frs_a address in the url shortcut.
Does WMP give you the error below if you double click the mmms-b shortcut?
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
that's it exactly!
I got that error message when I double click it
    4,00 Go
    1366x768
yes, but it worked before without any problem?!
    4,00 Go
    1366x768
that's it exactly! I got that error message when I double click it
Ok, this is good information. You'll have to compare the working system against the non-working system.
I'd start with Control Panel\All Control Panel Items\Default Programs
Set Default Programs -> make sure WMP has all of it's default
Set Associations -> scroll down to the Protocols section and make sure WMP has the mms: protocol
After that, it's a hunt - compare the configuration in WMP and note any differences. Then apply the differences to the non-working machine, one-by-one. Do NOT change the working machine :)
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
I set WMP as my default program.
the only difference that I found : that my laptop has [DLNA-PLAYSINGLE URL:DLNA-PLAYSINGLE Protocal] added. but the other doesn't as you can see in the images.
    4,00 Go
    1366x768
finally I found the culprit.
Set you default program => Internet Explorer => Choose defaults for this program => then I tick the '.url' and saved and it really worked
many thanks Starlybart
    4,00 Go
    1366x768
You're very welcome NourinE.
Excellent work - glad you had a working system to compare and very glad that the issue is resolved.
Thank you for posting the solution that worked on your machine - other members might benefit from your work.
When you get the chance, would you please mark your thread as solved - thanks again.
Bill
    HP
    HP 2072a (20" LED)
    1600 x 900
    WD 500 GB external
    HP product specs:
