Solved Partitioning UEFI enabled system for clean install
possible solution would be to go to control panel /administrative tools /services ,and scroll down to Intel rapid storage and turn it on
Service keeps stopping although set on Automatic - I did start it rebooted to find same story again
Any other workaround?
Thank you
    Windows 8 64-bit OEM Install Upgraded to 8.1 through Store
    HP ENVY dv6
    Intel(R) Core(TM) i5-3210M CPU @ 2.5GHz
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Resolved
Thanks everyone for extending help in one or other way, the problem is resolved, I relied on built-in HP Support Assistant which showed all drivers are up-to-date, however, that wasn't the case - after updating from Intel website it is working without any issue(s)
Thank you once again
    HP ENVY dv6
