Offical release for MSDN and TechNet subscribers
  • August 15: MSDN and TechNet subscribers will be the first to get access to the new software.
  • August 16: Software Assurance customers and Microsoft Partner Network members will get access to the operating system.
Will be nice to hear some reviews of the real thing, anyone around here a subscriber?
TC
Probably 10 per key. I have used one of mine 3 times on the same PC. :p
Don't ask.
Jim :cool:
I have found that the retail keys for Win7 from Technet pretty much has a really high number of installs per key. I have wiped and reloaded that damn key a good dozen times on my main machine that I continually hardware upgrade and have a few activations on my HTPC using the same key. I have yet to get any activation failed...
I don't expect windows eight to be nearly as generous as windows 7.
I don't think MS is doing anything different with the Windows 8 TechNet keys than with the others, contrary to the false rumors.
Jim :cool:
    ASUS - Home Built
    AMD Phenom II X6 1100T
    ASUS M5A99X EVO
    MSI R6850 Cyclone IGD5 PE
    On Chip
    Corsair 400R
    AVS Gear Blue LED Backlight
    15MB
    NIS, Malwarebytes Premium 2
    Epson V300 Scanner
Jim :cool:
Do you have something to base that on?
    W8.1 Pro 64
    Custom Build Desktop
    Core I7-4770 Haswell
    Intel DH87RL
    16GB
    Onboard 4600 with (3) DVI monitors
    On board
    (3) 19" LG L1942PE DVI
    1280 x1024
    HD Green 4TB
    Samsung SSD
NCguy, it's called TechNet inertia. Changes seem to break everything MS touches so they will probably leave it alone...
    Windows 8.1 Pro 64 bit GA
    i7-4770K Haswell
    ASUS Z87-PRO
    16 GB of Corsair 1866
    GTX 780
    Cooler Master Storm Headphones
    Dell 27 inch U2711 IPS
    2560 by 1440
    Samsung 840 Pro 250GB SSD plus 2 3 TB drives
    Corsair-750
    Corsair White Graphite Series 600T
    Corsair H00i Water
    Corsair K90
    Logitech G9 Laser
    6.3 MBps
    MS
I hope you're right but I sense its bend over time
    W8.1 Pro 64
    Intel DH87RL
    16GB
    On board
    1280 x1024
    HD Green 4TB
    Samsung SSD
Interesting. Win8 Pro Retail from Technet silently activated Windows with my product key without any input from me. Y'know, clicking the "Windows needs to be activated" icon that pops up on Win7. I think that is part of the new hammer down on piracy policy that MS has implemented with Win8.
Yeah, its a bummer for somebody like me who installs a VM, tests something and then simply blows away the VM. In the past, I simply just installed without a key and never had to activate since my machines only lasted a few hours to a few days at most.
Oh well, I will just use the "enterprise" copy of the software for this type of testing purposes. With 5 keys for Pro and multiple activates per key, I shouldn't have any issues.
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
Hi there pparks1
How about creating a Base VM (or "Reference VM") with nothing special installed apart from Windows Default.
Use this as "The activated version".
Now "Clone" this VM to another VM and build the VM you want for your testing.
You might get "Hardware has changed - Please Activate Windows -- now see if you get 3 or 30 or whatever number of days.
If you get a few days grace before you have to activate then this should work just like you did it before. The trick is to keep a "Standard Reference" VM which you use as a model for your Test VM builds.
Incidentally does the Enterprise version actually require an Internet connection to activate when you enter the product key via the slmgr command. I believe it just activates anyway -- normally these versions look for a KMS server which I don't have available which is presumably why it didn't activate normally but entering a valid product key achieves the same object.
I should have tested this by disconnecting from the Internet - but I forgot. !!
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
I have done activations over the phone before for systems not connected to the internet (secure networks) and, while it works, it's not fun. I have never had a problem getting that to work but then I have also never tried it with Windows 8. There is (or was) a step-by-step process the system will walk you through - ultimately you get a code back from the system and you're directed to call a number (based on your location), enter the code you got from the system, and then enter the characters you get back from Microsoft (on the phone) to complete the activation.
It's not fun, as I said, and we stopped doing it in favor of allowing communications between the secure network and our corporate KMS for the prupose of activation. Making a phone call every time we install another machine on a secure network is just not practical but for one or two machines it's OK.
Out of the box Enterprise didn't ask for a key; presumably it will look for a KMS, like Windows 7 Enterprise does. If there is no KMS or you want to use a MAK key then you need to "install" that key. I did that and then the systems shows as "activated" - I didn't need to manually activate it once I entered the product key using slmgr.vbs. (At least in Win8 Enterprise there is no "change my product key" link on the Control Panel like there is in Win7 Enterprise. I don't know if Pro behaves the same way.)
    Windows 7 x64
I do intend to try this type of procedure when time permits.
Cheers
jimbo
I'll give it a shot, but I'm pretty sure you have to be connected to the Internet for the activation to be successful. Otherwise, you get a prompt saying to call it in. I'm pretty sure this was the same as how it was in Windows 7.
    Windows 7
    23" Acer x233H
    Antec P182
    stock
    ABS M1 Mechanical
    15/2 cable modem
I'm going to try to activate my VM using slmgr.vbs without a NIC connected and see if it says activated, and stays activated after a couple of days.
You can get the change product key button back if you run slmgr.vbs -upk (uninstall product key).
I haven't tried the Pro version yet, but I read that it does have a change product key option...and you also need to input a legit key to even install it in the first place.
    Windows 7
    23" Acer x233H
    Antec P182
    stock
    ABS M1 Mechanical
    15/2 cable modem
Yeah, since Enterprise is for VL customers it's likely they'll have a KMS set up, and the product will activate automatically (once the threshold is reached, anyway). Without a connection to a KMS you can use a VL key but my experience, at least with Win2008 R2, is that even with the VLK you need an internet connection for activation (unless you want to do the telephone activation). My memory may be a bit faulty on that last point (I think we entered a VLK before we did the phone activation but maybe it was during that process).
    Windows 7 x64
Ok guys,
I took a VM, disconnected from NIC and ran the slmgr.vbs -ipk "key" command and it accepted my key just fine. 5 seconds later, it prompted me with a thought bubble to "Activate Windows now".
When I check the activation status, it has a button to "activate by phone" or "activate".
So, this has to be activated via normal channels.
    Windows 7
    23" Acer x233H
    Antec P182
    stock
    ABS M1 Mechanical
    15/2 cable modem
Is Windows Media Center in the TechNet Win8 Pro retail release?
    i7-4770K Haswell
    ASUS Z87-PRO
    GTX 780
    2560 by 1440
    Corsair-750
    Corsair H00i Water
    Corsair K90
    Logitech G9 Laser
    6.3 MBps
    MS
No, only Media Player.
    Windows 8.1 Pro RTM x64
    Dwarf Dwf/11/2012 r09/2013
    Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
    ASRock Z77 Extreme4-M
    4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
    MSI GeForce GTX770 Gaming OC 2GB
    Realtek High Definition on board solution (ALC 898)
    ViewSonic VA1912w Widescreen
    1440x900
    OCZ Agility 3 120GB SATA III x2 (RAID 0)
    Samsung HD501LJ 500GB SATA II x2
    Hitachi HDS721010CLA332 1TB SATA II
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    XFX Pro Series 850W Semi-Modular
    Gigabyte IF233
    1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
    Microsoft Comfort Curve Keyboard 3000 (USB)
    Microsoft Comfort Mouse 3000 for Business (USB)
    NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/sec (O2)
    IE 11
    Avast! 8.0.1497 MalwareBytes 1.75.0.1300
    Optical Drive: HL-DT-ST BD-RE BH10LS30 SATA Bluray
    Lexmark S305 Printer/Scanner/Copier (USB)
    WEI Score: 8.1/8.1/8.5/8.5/8.25
    Asus Eee PC 1011PX Netbook (Windows 7 x86 Starter)
It is there but you need a Windows 8 Pro with WMC product key to unlock it. I tried one of those leaked keys with Add Feature and it installed WMC and worked great. Except that key was blocked and it killed my activation. I tested it for a while but then re-installed my Pro version.
Jim :cool:
    ASUS - Home Built
    ASUS M5A99X EVO
    On Chip
    Corsair 400R
    15MB
    Epson V300 Scanner
Ok guys,
Nice. Good to know we can activate this way.
    Windows 7
Wouldn't the Official release be the same as the evaluation issue that we have now?
    Windows 8 Pro
    HP Pavilion g7-120us Notebook
    8 GIG
