Solved Network Wifi Connection Problem
midou35000
Coming Over
Canada
Hi,
So The Problem is that i changed my SSID on my router because i have created a hotspot by mistake with a same
SSID of my router Wich is named DJAWEB and it was annoying so i changed my router`s SSID To Djaweb it worked fine but i still see the other SSID (DJAWEB) of my computer hot spot and i couldnt remove it or forget it by using the only way wich is(image attached):
so any ideas how to turn off hotspot(network sharing) and remove that annoying SSID from my wifi connection (image attaced):
    Windows 10
    HP
    Intel Core i7
    Nvidia Geforce GTX 680
    idfk
    15' 1080p display
    70Mbps
    Google Chrome Canary
    AVAST Premiere 2015
To manually turn the Hosted Network off, enter the following into an elevated command prompt:
netsh wlan stop hostednetwork
You can also disable the Msoft virtual WiFi adaptor in Device Manager by going to the View tab then enabling "show hidden devices" you can then right click the virtual adaptor to disable as shown in the pictures. :)
How to Delete or Forget Wireless Network Profiles in Windows 8.1
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
You can also disable the Msoft virtual WiFi adaptor in Device Manager. :)
Hi,
i Couldnt find Microsoft virtual WiFi adaptor in Device Manager.:)but i did the first one you told me :)
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
