I do not know how to explain this problem on Window 8
ineedhelpyo
I've uploaded 2 images for your reference to my problem. As you can see from the image, for image1(ControlPanel), image2(Mail) , both are enclosed with a white bracket, if im not wrong, the bracket indicated that you can start navigate the pages using up down right left arrows. This feature automatically turned on when i switch on my laptop. It should not be like this previously, i believe that i did unintentionally pressed something on the keyboard that lead to this to happen.
I know its not a big problem but i doesnt feel good to see my window 8 has this feature automatically turned on. Please help me. Thanks
http://s25.postimg.org/7hgm0xbzj/Capture.png
http://s25.postimg.org/4onegwbn3/Capture1.png
    window 8
It means you can start it with Enter button.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I don't have it by default. When I press the :winkey: nothing has focus (that is the box around it). When I press any of the arrow keys (down in this case) then a box appears aound the item with focus and is selected when you press enter. Is that what you mean?
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
First item top left (Start Screen) or top list item (Charms Bar) always has focus when either Start Screen or Charms Bar is opened, although the focus indicator is at this point invisible. Pressing Enter executes this first item with invisible focus indicator, to select any other item with keyboard and and make the focus indicator visible, use the arrow keys. This is a default Windows 8 / 8.1 feature.
    HP ENVY 17-1150eg
    6 GB
    1600*900 (1), 1920*1080 (2&3)
    50 MB VDSL
    Maxthon 3.5.2., IE11
    Windows Defender 4.3.9431.0
So it does. Thanks Kari. I didn't notice it before.
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
In my case i dint press anything but the focus appear *its visible. Here is another example of problem : http://s25.postimg.org/ha1npjgfj/Captu1re.png , Normally, when u click the volume icon at the bottom right, there should be dotted line around the volume, but now i have it and i can dirrectly adjust the volume using up or down key.
    window 8
Not sure what you are saying. I don't have the dotted line on the volume icon when I click on it but can increase or decrease it with the arrow keys.
Not in my case, no - see below.
I can still adjust the volume using the keys...
Sorry - perhaps I'm just not understanding the question.
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
you can refer to my original question on top. So basically my problem is why the bracket (focus) appear automatically, yours is okay. When you open up charm bar, your icon wont be selected automatically with visible white bracket ( refer to image uploaded )
    window 8
It looks different when opened thru Charm bar than from Task bar on desktop and has only main sound volume as opposed to taskbar one which has Mixer and all sound devices.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
its obvious yours are highlighted ,ours are not ,but we/I can still start navigating with the arrow keys ,but finding out what caused it will be a challenge for sure ,you could try a system restore back to a time before it started doing so, or just ignore it as it doesn't cause any real problems with using windows
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
