How many use W8 CP as their main OS?
Very much looking forward to either a new official build or a leaked one, just to see where they are going with this.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Other than that it's been way more stable for me compared to Windows 7, especially when gaming.
So you must have a problem in your Windows 7 PC, mine is stable as rock
    Windows 8 enterprise x64
    Pc-Quebec / Area 66
    i7-3960X Extreme Edition
    Rampage IV Extreme
    Gskill 4x4 GB
    4 x HD 7970
    onboard
    2560*1600
    C:\Intel series 520 SSD , 250 GB
    D:\ WD 750 black with Intel 40gb SSD cache Intel RST
    E:\ WD 2TB Black
    Corsair AX 1200
    TT Mozart TX
    Water Cooled
    Logitech G-15
    Windows 8 VM is install on his own SSD.
Same PC, Windows 8 is just more stable with this particular motherboard for some reason. Windows 7 would freeze up sometimes, but only when playing certain video's. This never happens with Windows 8. All my other Windows 7 machines seem fine in this regard.
Msoft changed the audio stack in Windows 7 to prevent errant audio bytes from causing crashes. I believe they changed something in Windows 8 to prevent graphics driven crashes or freeze ups because it's definately working better for me on this machine.
Did your G15 keyboard cause any issues for you? It certainly did with this machine, I had to mess with the HID drivers to get this keyboard to work right with Windows 8.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Thanks for all your answers! Useful comments.
I read somewhere that using this CP could corrupt your files. Is that true? Sound like BS. But want to be sure. Don't want to risk losing files, before I have the chance to do my monthly backup procedure
Also, will the RC be released to the public?
    W7 x64
I've been using the Windows 8 since the Developer Preview back in September and now the Consumer Preview. Yes, I have been running them as my main OS. The only way to get a good feel for a new operating system is to make it your main OS so you can get into the nitty-gritty of it. I also have 7 dual booted, I'm not that insane. :cool:
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
Never heard of Win8 corrupting any files.
As long as you have your personal files/data in a separate partition when you install Win8 you won't loose anything.
You can also make a separate partition to install Win8 in, leave your Win7 install intact for a while so you can transfer any files you may need. This is Dual booting, you can boot up either OS.
The RC is usually released to the public, haven't heard anything different for Win8.
    76~2.0
    Intel Core i5-3570K 4.6GHz
    GIGABYTE GA-Z77X UD3H f18
    Onboard VIA VT2021
    22" LCD Dell SP2208WFP
    1680x1050
    Corsair HX650W
    Cooler Master Storm Scout
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
    Desktop: eSATA ports,
hi all since installing windows 8 as my Main system..since feb 29
this much has happened..
good things
1. fast bootup and shutdown..love it
2. explorer is good for copying and moving files..love that
3. uummmm ummmm..
bad things
1. lots of programs not running well in w8 especially anti virus, benchmarking etc..ok its beta so we will have to see
2. metro ..wats that .i use it only when i get tired of the desktop interface..not really practical for a desktop pc
3. internet explorer metro interface is not working and all its links on the metro..i understand u must make internet explorer the default .. i use google chrome a lot???
4.where is the start button..i need to find those seldom to use program quickly...dont want it on my taskbar or desktop alas i have to go to metro..hahhaah
5.i place my taskbar at the top now..this is so as to left hand bottom click easily to go metro..bummer
6.and where is the shutdown button..u would think it would be everywhere a big red button..noooo
7. more to come thats life
in conclusion ...its w7 without the start button ...and a little metro if u like..seems u get dump to desktop from the metro interface quite often too ..
    w8
I would, except there will be no upgrade path from CP to RTM. Sticking to dual boot because of that, trying to use 8 whenever possible. Using dropbox to keep files synchronized between 7 and 8.
    Win7 / 8CP
I wanted to use it as the main OS on my netbook, but my school has a programme to set up the university wifi network and it doesn't work with W8.
    Windows 8 Home 64-bit
    N/A
    Gigabyte H67A-UD3H-B3 rev 1.0
    8 GB DDR3
    NVIDIA GTX480
