HELP! Stuck at automatic repair loop... WONT BOOT.
I see. I guess I am not surprised that you are getting no where with a flash drive at this point. Is this the same flash drive you mentioned in your post #1 or is it one set to boot into Windows for use rather than install?
Edit: Check post #20 out on this thread.
I only have one flash drive, so yes its the same flash drive, I had to reformat all the windows 8 boot files and installed it fresh new.
I have 500gb portable usb HDD, so I'll try on that.
Good luck.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
I had exactly the same problem you're experiencing. I fortunately have an eSATA connected external drive that is a ghost copy of my original Windows 7 boot disk prior to my Windows 8 install (smartly don't trust new operating systems). I booted from that and didn't find any hardware issues with my system or HDs. I tried everything in the book to restore my Windows 8 environment. Apparently there was an auto update that Microsoft did that caused the problem. It corrupted the Windows registry in some way that was un-repairable. I had to re-install Windows 8 again. I was able to save files but needed to re-install all my programs again. I am back up and running on Windows 8 again.
Couple of comments:
- Don't install Windows 8 on mission critical systems yet. It is just not stable. It needs a service pack or two.
- The Windows 8 repair programs leave a lot to be desired.
- I turned off auto update and will do it manually so I can watch.
Wow I just installed Ubuntu 12.10 on my Portable USB HDD, and wow it runs fantastic!
So I checked my Devices and it showed 2 drives.
I had 2 partitions on my Windows 8 before, 2 local drives, C and D. My C drive is where my my windows 8 and all my stuff were restored, I had D drive just as a back up but I didn't actually put much in there because I thought it would be useless.
So now only my "D" partition shows up, but the "C" partition where windows 8 was installed doesn't show up.
Overall I am just really glad that it atleast boots up to a solid OS, and it recognizes atleast one of my parition. From here on, I need help on restoring my "C" parition, how to fix it, or how to get my files again.
I have absolutely no knowledge on Ubuntu. I really need help on this.
ZNOD,do you know of any Ubuntu based software that allows you to retrieve files from lost partitions like the ones you quoted before?
@nick
That must have been the case! because it did say it was auto updating, and the next morning I woke up and tried to turn it on and there it was trying to diagnose itself.
I am not sure if I do want to install Windows 7 or Windows 8 after I get my files back though (if I do get them back).
Sorry, I know little about Ubuntu. You could PM some of those having familiarity to maybe get some help.
    EVGA 570 SC
    Gateway
    Dual Boot:
My solution: Put in the windows 8 DVD and boot from it. It said " will restore system to an earlier point". Yes it will take a while but it worked for me.
ByaTsuke you will get loads of info from ubuntuforums.org site. It has everything you need.
Install Gparted and then open it and report what partitions/details are shown please.
There is one Linux based program I know of which can recover lost partitions (and sometimes just its files) but that would depend on the circumstances. That program is Testdisk, but don't go playing with that just yet. It is a very powerful tool and although you may be able to get everything back with it you can also lose everything with it too!
As I understand it you have now installed Ubuntu on the same pc that you had Windows 8 on, but in a different partition. Is that correct? What installation options did you choose during the Ubuntu installations (eg side by side, use whole disc etc etc)?
Ubuntu is very good nowadays and can be used to fix many Windows problems too.
    OS X / Windows 8.1 Pro / Ubuntu 13.10
    15" MacBook Pro retina 10,1
    2.3GHz
    8GB 1600MHz
    Intel HD400 / Nvidia GT650M
    2880 x 1800
    256GB SSD
Among other things, his C: drive is shown to be locked under Windows.
    EVGA 570 SC
    Gateway
    Dual Boot:
Unfortunately, I have the same exact problem. I just went to pc to transfer some photos to my phone, after that I saw that there was an update installed by Windows Update and the pc was needed to be restarted in order to apply changes. After I finished tranfering simply I shutted down the computer. BUT, I forced shutdown, there was Steam, Notepad and a program that I don't remember were running in the background. After a minute or so, I realized that I forgot to do something and went to the PC. New BSOD = Automatic Repair Loop of Death (ARLOD).
You know the other part of the story... Even though I can't explore files with Linux Mint LiveUSB, I can somehow copy/write the files through recovery Command Prompt, so I'll try to recover my files and downgrade to Win7 until MS releases Win8 SP1.
Intel Core 2 Quad Q6600 @ 2.4 GHz
Asus Nvidia GTX 560 Ti DirectCU II TOP
2x2 GB DDR2 Ram
120 GB SSD (One partition which has Windows installed) + 500 GB HDD (Two partitions)
Asus P5K-SE
Windows 8 Enterprise x64 (Despite the name of the edition, it seems that it is not stable enough for these things :( )
EDIT:
Thanks to this: Jarrad - Windows 7/Vista Startup Repair Loop of Horror
Now I can see the error number. It says that there was an unexpected I/O error x_x. Error code:0xc00000e9
It seems that it may be my SSD's problem. I have a Corsair 120 GB Force 3 GT. I had and old firmware, 5.02. Not because I was lazy. That was because I couldn't update to 5.03 with their crappy programs. Though, to be honest, I should've tried updating it with Linux. That may be the problem.
FIXED:
Well, I changed my mind and the problem I encountered may be different from the problem happened in computers of people over here. It seems that, my C: drive was locked but after some time, it was fixed spontaneously. That time - I didn't realized it was unlocked already - I could copy/write files with Cmd. So the only problem left was missing or corrupt files. I just went ahead and hit "Refresh" again. This time, Refresh feature worked. Though, I could use sfc /scannow to prevent losing the options, but it doesn't matter. Sorry, I misunderstood that the problem was Corsair's old firmware's fault (and partly my fault also). There is nothing MS can do about hardware failures which damages system files.
    Windows 8 Pro x64
    Intel Core 2 Quad Q6600 @ 2.4 Ghz
    ASUS P5K-SE
    2x2 GiB
GUYS!
I am back on Windows 8, I'll explain every bit of detail.
Booting Linux Ubuntu, I tried many different partition softwares. Testdisk worked amazing, it was able to access through my "C" partition which gave an error when trying to access normally, so I was able to copy back all my essential files into my portable HDD.
HOWEVER...
I wasn't able to format my C drive, tried every bit of software, so I decided to use a complete wipeout from boot by a software called "DBAN". . .
It did wipeout my entire drive by a process that took around 20 hours, and my HDD was making really odd noises, like the one it makes when you first boot your computer.
Anyways, I then tried to boot my Windows 8 disk again one more time (wasn't working before) and this time it worked! It wasn't stuck on loading like before.
So then it asked me where to install Windows 8. My internal HDD was now just unallocated space, so I turned that into a partition.
Windows 8 said that the hard drive may fail soon, but I installed it anyways.
I am on Windows 8 now, everything works fantastic, infact I feel my HDD loads little bit faster than before.
BUT........................................
Since during installation windows said my hard disk may fail (after wiping it out using DBAN), I used HDD REGENERATOR to check for bad sectors. It took hours and it found 25000+ sectors and still counting, I figured it may be my entire drive that could be the bad sectors, so I figured it must be a logical error in how it reads my HDD, so I quit the process.
I used chkdsk /f, which took few minutes showing no sign of error, I checked my disk errors on windows 8 it said no errors were found.
I am still happy that my computer is atleast working smoothly, but with over 25000 bad sectors still counting don't know how many bad sectors there really are, maybe my entire drive :), which I am guessing is around 900 thousand? or 9 million? not sure but it was a long number.
It is not a physical bad sector error, I don't think it would be at all.
Yep, did all I could on Ubuntu. Recoverd my files and then tried to format my HDD, it didn't work. So I used a bootable software called DBAN, which wiped out my entire HDD, but read the whole story above.
It does sound like it may be an HDD problem, I think.
Try going to the manufacturer's website. Most of them have a utility you can download for checking the hard drive.
    2.3GHz
    8GB 1600MHz
    2880 x 1800
    256GB SSD
Well, the really good news is that you got the critical files back. I'll bet you'll keep them well backed up in the future? And, way to go!
    EVGA 570 SC
    Gateway
    Dual Boot:
I have WDC so I used their diagnosing tools, and it scans lot faster than 3rd party softwares.
It does give me an error saying its unable to fix even though it finds the error, but anyways showing the "S.M.A.R.T" info of the HDD, only my "Re-Allocated Sector Count" has failed,
value - 139
Threshold - 140
Worst - 139
Warranty - 1
I am not sure what exactly these numbers mean, but I am guessing it's off by 1. If anyone knows about this, please translate it for me ;).
@znod, yes indeed, I have backed them up into my external HDD. Testdisk is amazing though, I was able to recover all my files fully. So next time if my HDD becomes corrupt or if I identically delete my files from my trash bin, I'll still be able to retrieve them, but very unlikely that I'd delete them intentionally.
value - 139
Threshold - 140
Worst - 139
Warranty - 1
@znod, yes indeed, I have backed them up into my external HDD. Testdisk is amazing though, I was able to recover all my files fully. So next time if my HDD becomes corrupt or if I accidentally delete my files from my trash bin, I'll still be able to retrieve them, but very unlikely that I'd delete them intentionally.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
It's time for a new drive by the looks of it.
Did you recover the whole C: partition with Testdisk? That's usually the easiest way, if it can manage it. It's a great little program.
    2.3GHz
    8GB 1600MHz
    2880 x 1800
    256GB SSD
GUYS!
HOWEVER...
I had once a customer with an external WD HDD, which was still recognized, but not accessible anymore in a normal way. On the HDD was all the pictures from their baby, like a daily picture diary, to see how the baby is growing up etc.
It took me 8 Days/Nights and multiple scans with HDD Regenerator to repair ~57.985 Bad Sectors and recover 25.7 GB on Data, which I got of the external HDD via TestDisk.
The customer only lost 2 (!) pictures in the whole process.
It's very time consuming, but it works.
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
The instructions below (taken from several posts) helped me repair a Windows 8 boot camp installation on a macbook pro core duo.
To manually repair a windows 8 bootcamp installation that is stuck in automatic repair, try this...
1. Boot to Mac OSX
2. Download DOSBox DOSBox, an x86 emulator with DOS for MAC
3. Show hidden files on mac
First, open Terminal.
Type this command, then press enter:
defaults write com.apple.finder AppleShowAllFiles TRUE
To allow the files to be shown, you must restart Finder. You can do this by holding the Option key, click and hold the Finder icon. When the context menu shows, select Relaunch.
Finder will now restart.
Now all hidden files are showing!
(After fixing windows 8....
To hide files again, type:
defaults write com.apple.finder AppleShowAllFiles FALSE
In the terminal instead, and restart Finder.)
You can also restart finder by using the following command from the terminal:
killall Finder
4. Open DOSBox and do the following:
Type mount c "Volumes/BOOTCAMP" and press Enter. This will mount your windows installation at the root of the drive
Type cd Boot and press Enter. This navigates to the Windows 8 boot options.
Type attrib bcd -s -h -r and press Enter. This allows you to modify and overwrite the boot options.
Type ren bcd bcd.old and press Enter. This renames the current boot file.
5. Reboot into windows and it SHOULD rebuild the boot file
Good Luck!!
    Apple MacBook Pro Core 2 Duo P8600 2.4GHz 4GB 250GB DVD±RW 13.3" Notebook AirPort OS X w/Webcam, 6-C
    20MB +
