Save the following code to the root of the setup media USB as ResetPartitions.txt
Use diskpart to find the drive letter assigned to the USB Drive
diskpart
list volume
exit
now from the command prompt
diskpart /s X:\ResetPartitions.txt
X being the drive letter assigned to usb drive
the /s tells diskpart to run a script
Because, you have been running incomplete command lines when setting up your partition(s)
Use diskpart > list volume
to verify 4 partitions...
then continue windows setup using existing partitions...
if windows setup does not find the drive - copy the expanded dell drivers
5830_Intel Atom Z3000 Series Driver_603.9600.2067.27988
into a drivers folder on the root of the usb then point setup to look for the needed storage driver in that folder..
rem == ResetPartitions-UEFI.txt ==
select disk 0
clean
convert gpt
create partition primary size=350
format quick fs=ntfs label="WinRE Tools"
assign letter="T"
set id=de94bba4-06d1-4d40-a16a-bfd50179d6ac
gpt attributes=0x8000000000000001
create partition efi size=100
format quick fs=fat32 label="System"
assign letter="S"
create partition msr size=128
format quick fs=ntfs label="Win_OS"
assign letter="W"
list volume
exit
diskpart
list volume
exit
- Windows 3.1 > Windows 10
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Dell XPS 8700
- CPU
- I7
- Memory
- 24 GB
