chev65
Closed
- Location
- Beach house paradise
Yeah that's a good way to describe it. I just got this one like a month ago, and it was the newest one they had lol.
So you are saying for the PCI cards that even if they say 10/100/1000 then they are still capped at 100?
Yes with the router you have now everything will be capped at 10/100 not 1000 or GB capable at all. Not to mention it's only wireless G capable, not N, not AC.
Is a matter of fact the specs on this router are over 10 years out of date. You would be far better served with a dedicated modem and a newer model router that is GB and wireless N capable. This would most likely solve your problems.
I figure it will hold me back some but I just don't think it's what caused this problem though.
So in your opinion would i be served well by getting a NIC card regardless if I upgrade the router or not?
An Ethernet card would be the cheapest option but it may or might not fix the problems related to the handshake between these devices. It's a cheap gamble and might be worth trying for that reason.
- Windows 8.1 Pro WMC
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Home built
- CPU
- Q9650 @ 4.05 GHz
- Motherboard
- Gforce 780i SLI FTW
- Memory
- 8GB Gskill DDR2 1200Mhz
- Graphics Card(s)
- GTX-480
- Sound Card
- Asus D2 Xonar
- Monitor(s) Displays
- HannsG
- Screen Resolution
- 1680x1050
- Hard Drives
- Gskill 120GB SSD
- PSU
- Thermal Take 1000watts
- Case
- Thermal Take Xtreme
- Cooling
- 9 fans air cooled
- Keyboard
- G15 logitech
- Mouse
- G9 logitech
- Internet Speed
- 50mbps
