Solved Frequent, random reboots with Event 41, Kernel-Power
No problem, Axe0. Since testing clearly isn't working, I'll try an empiric approach -- run the computer with 1 stick for several days and see how things go. If it still crashes, it's either that RAM, or something more obscure, and iBuyPower will have to replace the machine. If it's stable, than presumably the other stick is bad, and iBuyPower can replace it.
I was hoping that one of the senior debuggers would find something in the logs I posted, but you appear to be on your own here.
    Windows 10 64 Pro
    iBuyPower
    Intel Core i7-4790K
    ASRock Z97X Killer
    16 Gb DDR3-2133 G.SKILL Ripjaws X
    EVGA nVidia GeForce GTX 980
    Onboard
    30" Dell 3007WFP
    2560x1600
    256 GB Samsung 850 Pro SSD, 2 TB WD Black, 2 Tb iOmega external
    850 Watt - Corsair RM850
    NZXT Phantom 410 Gaming Case
    Liquid-cooled CPU, case fans
    Razer Blackwidow Chroma
    Razer Deathadder Chroma
    Gigabit fiberoptic
    Chrome
    BitDefender Antivirus Plus 2015
Well, I hoped this chip was good, but perhaps not. After 72 hours without a problem, my PC just crashed while playing Elder Scrolls Online. No BSOD or memory dump to report, alas. I've attached a fresh set of logs, regardless.
Time to check the other RAM chip. Bah!
    Windows 10 64 Pro
    iBuyPower
    Intel Core i7-4790K
    ASRock Z97X Killer
    Onboard
    30" Dell 3007WFP
    2560x1600
    Gigabit fiberoptic
    Chrome
After almost a week without a crash on the remaining memory chip, I'm marking this issue solved. Now to get the bad RAM replaced by the manufacturer. Thanks for the help, all.
    Windows 10 64 Pro
    iBuyPower
    Intel Core i7-4790K
    ASRock Z97X Killer
    Onboard
    30" Dell 3007WFP
    2560x1600
    Gigabit fiberoptic
    Chrome
