How are you accessing the PC? You mentioned X which means your booting into ram and windows recovery?
After having no success I removed the drive and have been doing everything using a SATA to USB convertor cable on my VISTA laptop.
Prior to removing the drive and when I first started trying to find a non-destructive solution the computer would try to repair things and as I mentioned in the original post there were numerous different options offered and one was a command prompt. Years and years ago I used MS-DOS a fair amount so started going through different drive letters and then using dir to find out what was on the given partition, well I guess volume, as dynamic drives technically don't use partitions. It has been a little while and I have done so much since but if I recall correctly when I first went into a DOS window the prompt was x:\windows\system32 so after trying c and d and finding they were both recovery partitions I went back to drive x and it appears to contain the original contents of drive c if you know what I mean.
- 8.1
