How to Add or Remove Control Panel from Navigation Pane in Windows 8 and 8.1
Information
This tutorial will show you how to add or remove Control Panel from the navigation pane of File Explorer for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
This includes Control Panel for when Show all folders is checked and not checked.
EXAMPLE: Control Panel added and removed from navigation pane
1. If you have not already, you will need to take ownership for Administrators first with the Replace owner on subcontainers and objects box checked, then set permissions to "Allow" the Administrators group "Full control" of the {26EE0668-A00A-44D7-9371-BEB064C98683} key in the registry (regedit.exe) below.
HKEY_CLASSES_ROOT\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}
2. If you have a 64-bit Windows and have not already, you will need to take ownership for Administrators first, then set permissions to "Allow" the Administrators group "Full control" of the ShellFolder key in the registry (regedit.exe) below.
NOTE: This step does not apply to 32-bit Windows.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\ShellFolder
3. Do step 4 or 5 below depending on if you have a 32-bit or 64-bit Windows 8 installed.
4. If you have a 32-bit Windows 8, download step 4A, 4B, or 4C below for what you would like to do, and go to step 6 below.
A) To Add "Control Panel" to Navigation Pane
32-bit_Add_Control_Panel_to_Navigation_Pane.reg
B) To Remove "Control Panel" from Navigation Pane
32-bit_Remove_Control_Panel_from_Navigation_Pane.reg
C) To Restore Default "Control Panel" in Navigation Pane
NOTE: This is to only have the Control Panel display in the navigation pane when you have Show all folders checked.
32-bit_Default_Control_Panel_Navigation_Pane.reg
5. If you have a 64-bit Windows 8, download step 5A, 5B, or 5C below for what you would like to do, and go to step 6 below.
64-bit_Add_Control_Panel_to_Navigation_Pane.reg
64-bit_Remove_Control_Panel_from_Navigation_Pane.reg
64-bit_Default_Control_Panel_Navigation_Pane.reg
6. Save the .reg file to your desktop.
7. Double click/tap on the downloaded .reg file to Merge it.
8. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
9. Restart explorer, sign out and in, OR restart the PC to apply.
10. If you like, you can delete the downloaded .reg file if you like.
- How to Add or Remove Control Panel in This PC in Windows 8 and 8.1
- How to Show or Hide Navigation Pane in File Explorer in Windows 8 and 8.1
- Add or Remove "Libraries" from Navigation Pane in Windows 8 and 8.1
- Add or Remove "Favorites" from Navigation Pane in Windows 8 and 8.1
- How to Add or Remove "Homegroup" from Navigation Pane in Windows 8 and 8.1
- Add or Remove "Network" from Navigation Pane in Windows 8 and 8.1
- Add or Remove "SkyDrive" from Navigation Pane of File Explorer in 8.1
- How to Rename "Control Panel" in Navigation Pane in Windows 7 and Windows 8
- How to Turn Navigation Pane "Show all folders" On or Off in Windows 8 and 8.1
- Enable or Disable Access to Control Panel and PC settings in Windows 8 and 8.1
- How to Add or Remove "Control Panel" from Desktop Context Menu in Windows
32-bit_Remove_Control_Panel_from_Navigation_Pane.reg876 bytes · Views: 909
