hi guys,
can anyone help me with this BSOD please, i have had windows 8 installed 5 days now. I had a BSOD about 3 days ago but that said it was the graphics driver.
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
[FONT=Segoe UI, Arial]On Sun 20/01/2013 09:04:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012013-13010-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x7B340)
Bugcheck code: 0x109 (0xA3A039D898AC57FC, 0x0, 0x506EAA98182E4ACB, 0x102)
Error: [FONT=Segoe UI, Arial]CRITICAL_STRUCTURE_CORRUPTION[/FONT]
file path: C:\Windows\system32\ntoskrnl.exe
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: NT Kernel & System
Bug check description: This indicates that the kernel has detected critical kernel code or data corruption.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
[/FONT]
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntkrnlmp.exe[/FONT] (nt!KeBugCheckEx+0x0)
[/FONT]
Conclusion
[/FONT]
[FONT=Segoe UI, Arial]2 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
my ram has been fine, the only thing I have done different is install windows 8
[/FONT] I installed the new amd 13.1 driver yesterday morning I was using the 12.11 beta11 drivers b4 could that be it? the only other drivers I have installed are the sata and usb filter drivers from the asus web site
[/FONT]
[/FONT]
Conclusion
[/FONT]
- windows 8 64bit
- CPU
- Amd Piledriver 8350 4ghz
- Motherboard
- Asus Sabertooth 990fx rv.2
- Memory
- Corsair vengeance 8gb
- Graphics Card(s)
- Asus 7970
