BSOD error:dpc_watchdog_violation-help need please
kobyb
hello all
I have relatively new laptop aspire v3-571 that came originally with windows 7 and the option to upgrade to 8 and I took it when it came out and installed it.
I am not sure if it is related to the issue but few days after installing 8 the system stopped responding all together after a few minutes and I re-installed windows 8 so in the process all drivers and previous pre-installed software were deleted unfortunately.
since then it seems like working ok but I started to get those blue screens and more frequently now.
your help is most appreciated.
best regards all
koby
  • kobyb.zip
    acer aspire v3-571
    intel i-3
    4gm ddr3
    intel hd graphics 3000
Sorry for the delay in responding. There just aren't that many people who do BSOD analysis, so at times we get a bit overwhelmed!
This device is disabled:
Cisco Systems VPN Adapter for 64-bit Windows ROOT\NET\0000 This device is disabled.
Is this deliberate? If so, why?
Please:
- re-enable the device
- update the drivers/program to the latest, Win8 compatible version
- disable the device again if so desired
dne64x.sys Mon Nov 10 20:01:24 2008 (4918D964)
Citrix Deterministic Network Enhancer Miniport or Cisco Systems VPN Client
http://www.carrona.org/drivers/driver.php?id=dne64x.sys
CVPNDRVA.sys Fri Mar 4 14:43:37 2011 (4D7140E9)
http://www.carrona.org/drivers/driver.php?id=CVPNDRVA.sys
SYMDS64.SYS Mon May 16 18:15:03 2011 (4DD1A1E7)
Symantec/ Norton NIS/ N360 driver
http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS
ctxusbm.sys Tue Jun 7 18:53:28 2011 (4DEEABE8)
Citrix ICA Client USB Monitor Driver
http://www.carrona.org/drivers/driver.php?id=ctxusbm.sys
k57nd60a.sys Wed Oct 19 16:17:36 2011 (4E9F3060)
Broadcom NetLink Gigabit Ethernet NDIS6.x Unified Driver
http://www.carrona.org/drivers/driver.php?id=k57nd60a.sys
SYMNETS.SYS Sat Nov 12 16:11:53 2011 (4EBEE119)
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
Ironx64.SYS Mon Nov 14 21:00:53 2011 (4EC1C7D5)
http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS
SYMEVENT64x86.SYS Tue Nov 22 13:30:48 2011 (4ECBEA58)
Norton Internet Security
http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS
Analysis:
[font=lucida console]**************************Fri Jan  4 14:21:50.222 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-26140-01.dmp]
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 4:04:37.913[/B]
Probably caused by :[B]tcpip.sys ( tcpip!TcpProcessExpiredTcbTimers+c5 )[/B]
BugCheck [B]133, {0, 281, 280, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000133]DPC_WATCHDOG_VIOLATION (133)[/url]
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
    component can usually be identified with a stack trace.
Arg2: 0000000000000281, The DPC time count (in ticks).
Arg3: 0000000000000280, The DPC time allotment (in ticks).
Arg4: 0000000000000000
BUGCHECK_STR:  0x133
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]0x133_DPC_tcpip!TcpProcessExpiredTcbTimers[/B]
CPUID:        "Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz"
MaxSpeed:     2300
CurrentSpeed: [B]2295[/B]
  BIOS Version                  V1.06
  BIOS Release Date             04/20/2012
  Manufacturer                  Acer
  Product Name                  Aspire V3-571
**************************Fri Jan  4 10:16:36.162 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-29171-01.dmp]
System Uptime:[B]0 days 3:32:23.853[/B]
Arguments:
BUGCHECK_STR:  0x133
MaxSpeed:     2300
  BIOS Version                  V1.06
  Manufacturer                  Acer
[/font]
3rd Party Drivers:
[COLOR=RED][B]dne64x.sys                  Mon Nov 10 20:01:24 2008 (4918D964)[/B][/COLOR]
[COLOR=RED][B]CVPNDRVA.sys                Fri Mar  4 14:43:37 2011 (4D7140E9)[/B][/COLOR]
[COLOR=RED][B]SYMDS64.SYS                 Mon May 16 18:15:03 2011 (4DD1A1E7)[/B][/COLOR]
[COLOR=RED][B]ctxusbm.sys                 Tue Jun  7 18:53:28 2011 (4DEEABE8)[/B][/COLOR]
[COLOR=RED][B]k57nd60a.sys                Wed Oct 19 16:17:36 2011 (4E9F3060)[/B][/COLOR]
[COLOR=RED][B]SYMNETS.SYS                 Sat Nov 12 16:11:53 2011 (4EBEE119)[/B][/COLOR]
[COLOR=RED][B]Ironx64.SYS                 Mon Nov 14 21:00:53 2011 (4EC1C7D5)[/B][/COLOR]
[COLOR=RED][B]SYMEVENT64x86.SYS           Tue Nov 22 13:30:48 2011 (4ECBEA58)[/B][/COLOR]
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
SYMEFA64.SYS                Fri May 18 21:29:56 2012 (4FB6F794)
ccSetx64.sys                Wed Jun  6 23:00:55 2012 (4FD01967)
RTKVHD64.sys                Tue Jun 12 06:02:32 2012 (4FD713B8)
bScsiMSa.sys                Mon Jun 18 19:20:36 2012 (4FDFB7C4)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
btath_bus.sys               Thu Jun 21 01:22:17 2012 (4FE2AF89)
btath_lwflt.sys             Thu Jun 21 01:22:36 2012 (4FE2AF9C)
btath_avdt.sys              Thu Jun 21 01:22:40 2012 (4FE2AFA0)
btath_hcrp.sys              Thu Jun 21 01:23:29 2012 (4FE2AFD1)
btath_a2dp.sys              Thu Jun 21 01:23:44 2012 (4FE2AFE0)
SRTSP64.SYS                 Mon Jul  2 14:20:28 2012 (4FF1E66C)
SRTSPX64.SYS                Mon Jul  2 14:20:37 2012 (4FF1E675)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
iaStorA.sys                 Mon Jul  9 16:42:33 2012 (4FFB4239)
dump_iaStorA.sys            Mon Jul  9 16:42:33 2012 (4FFB4239)
BthLEEnum.sys               Wed Jul 25 22:25:02 2012 (5010AA7E)
EraserUtilRebootDrv.sys     Tue Jul 31 19:36:50 2012 (50186C12)
eeCtrl64.sys                Tue Jul 31 19:36:51 2012 (50186C13)
btath_flt.sys               Fri Aug  3 07:09:44 2012 (501BB178)
b57xdmp.sys                 Mon Aug 13 13:59:00 2012 (50294064)
b57xdbd.sys                 Mon Aug 13 13:59:16 2012 (50294074)
bScsiSDa.sys                Tue Aug 14 14:15:16 2012 (502A95B4)
athw8x.sys                  Wed Aug 22 23:18:39 2012 (5035A10F)
btath_rcp.sys               Fri Aug 24 11:27:40 2012 (50379D6C)
SynTP.sys                   Fri Aug 24 19:20:26 2012 (50380C3A)
Smb_driver_Intel.sys        Fri Aug 24 19:22:13 2012 (50380CA5)
IDSvia64.sys                Tue Aug 28 22:48:40 2012 (503D8308)
EX64.SYS                    Wed Sep  5 18:31:45 2012 (5047D2D1)
ENG64.SYS                   Wed Sep  5 18:33:39 2012 (5047D343)
btfilter.sys                Fri Sep  7 05:07:59 2012 (5049B96F)
igdkmd64.sys                Wed Sep 26 15:49:04 2012 (50635C30)
BHDrvx64.sys                Fri Oct 19 00:40:41 2012 (5080D9C9)
[/font]
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS
http://www.carrona.org/drivers/driver.php?id=ccSetx64.sys
bScsiMSa.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=btath_bus.sys
http://www.carrona.org/drivers/driver.php?id=btath_lwflt.sys
http://www.carrona.org/drivers/driver.php?id=btath_avdt.sys
http://www.carrona.org/drivers/driver.php?id=btath_hcrp.sys
http://www.carrona.org/drivers/driver.php?id=btath_a2dp.sys
http://www.carrona.org/drivers/driver.php?id=SRTSP64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS
BthLEEnum.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys
http://www.carrona.org/drivers/driver.php?id=eeCtrl64.sys
http://www.carrona.org/drivers/driver.php?id=btath_flt.sys
b57xdmp.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
b57xdbd.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
bScsiSDa.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=athw8x.sys
http://www.carrona.org/drivers/driver.php?id=btath_rcp.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=IDSvia64.sys
http://www.carrona.org/drivers/driver.php?id=EX64.SYS
http://www.carrona.org/drivers/driver.php?id=ENG64.SYS
http://www.carrona.org/drivers/driver.php?id=btfilter.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
