BSOD - driver_power_state_failure
Sir, it happens again today. My laptop can't read my hard drive when I plug in. Then when I restart my laptop, it is taking too long and the bluescreen appears again with the same message as before. What's happening now? Is there any outdated drivers again? Can you look into it?
    ASUS
    Intel(R) Core(TM) i7-4500U CPU @1.80 GHz 2.40 GHz
    4.00 GB (3.89 GB usable)
    GeForce GT 740M
    Realtek High Definition Audio
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    Razer BlackWidow Ultimate 2014
    Razer DeathAdder Black Edition
    1.5 Mbps
This not yet solved fyi
    ASUS
    GeForce GT 740M
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    1.5 Mbps
Sorry for the delay, I'm working longer hours for the holiday season and haven't had time to visit here.
It seems that it's been a month and a half since your last BSOD. As such I presume that we have to treat this as a new problem. I'll make suggestions for tests/procedures that will need to be done - even if you have done them previously.
Only 124 Windows Updates installed. Most systems have 160 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
Nothing clearcut in the memory dump. Please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Sat Dec 21 04:49:26.663 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\122113-39015-01.dmp]
Windows 8 Kernel Version 9200 MP (2 procs) Free x64
Built by: [B]9200[/B].16628.amd64fre.win8_gdr.130531-1504
System Uptime:[B]6 days 19:23:40.838[/B]
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSwapContext+76 )[/B]
BugCheck [B]9F, {4, 12c, fffffa80110d2b00, fffff803892f0910}[/B]
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
    subsystem.
Arg2: 000000000000012c, Timeout in seconds.
Arg3: fffffa80110d2b00, The thread currently holding on to the Pnp lock.
Arg4: fffff803892f0910, nt!TRIAGE_9F_PNP on Win7 and higher
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_4_nt!KiSwapContext[/B]
CPUID:        "Intel(R) Pentium(R) CPU 2117U @ 1.80GHz"
MaxSpeed:     1800
CurrentSpeed: [B]1796[/B]
  BIOS Version                  A03
  BIOS Release Date             12/25/2012
  Manufacturer                  Dell Inc.
  Product Name                  Inspiron 3421
[/font]
3rd Party Drivers:
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
iaStorA.sys                 Mon Jul  9 16:42:33 2012 (4FFB4239)
dump_iaStorA.sys            Mon Jul  9 16:42:33 2012 (4FFB4239)
Rt630x64.sys                Mon Jul 30 12:03:12 2012 (5016B040)
bcmwl63a.sys                Wed Aug 15 02:50:12 2012 (502B46A4)
igdkmd64.sys                Tue Aug 21 13:08:36 2012 (5033C094)
bcbtums.sys                 Fri Aug 24 17:21:36 2012 (5037F060)
btwampfl.sys                Fri Aug 31 17:06:30 2012 (50412756)
SynTP.sys                   Fri Sep  7 21:00:02 2012 (504A9892)
Smb_driver_Intel.sys        Fri Sep  7 21:01:40 2012 (504A98F4)
RTKVHD64.sys                Tue Nov 20 06:10:14 2012 (50AB6516)
ElbyCDIO.sys                Mon Mar  4 04:21:51 2013 (513467AF)
VClone.sys                  Sun Mar 10 20:49:12 2013 (513D2A08)
RtsUVStor.sys               Thu Aug  8 04:26:23 2013 (5203562F)
mfehidk.sys                 Wed Oct 30 16:16:03 2013 (52716903)
mfewfpk.sys                 Wed Oct 30 16:16:18 2013 (52716912)
mfeavfk.sys                 Wed Oct 30 16:17:09 2013 (52716945)
mfencbdc.sys                Wed Nov 27 01:04:06 2013 (52958B56)
[/font]
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=bcmwl63a.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
http://www.carrona.org/drivers/driver.php?id=btwampfl.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=ElbyCDIO.sys
http://www.carrona.org/drivers/driver.php?id=VClone.sys
http://www.carrona.org/drivers/driver.php?id=RtsUVStor.sys
http://www.carrona.org/drivers/driver.php?id=mfehidk.sys
http://www.carrona.org/drivers/driver.php?id=mfewfpk.sys
http://www.carrona.org/drivers/driver.php?id=mfeavfk.sys
http://www.carrona.org/drivers/driver.php?id=mfencbdc.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
