Solved it by using instructions. /Name:"Windows 8 Consumer Preview" obviously didn't work, so my 13-year brother advised to try using Index:1. That worked like magic!
So:
1. Download the Image. — it's the original MSDN windows 8 professional retail.
2. Burn to a flash drive using Microsoft windows 7 usb-dvd tool.
3. Follow instructions:
Update: no, that didn't work. I will try replacing this file while working under IDE mode.
Any instructions on how to get back to IDE mode if i switch my windows to AHCI not (through regedit)?
So:
All Fixed
Performed the following:
mkdir C:\mount
Dism /Mount-Wim /WimFile:L:\install.wim /Index:1 /MountDir:C:\mount (mount install.wim from flash drive L to local directory on disk C)
Use the Windows Search Feature and Search for "amdsbs"
Replace all amdsbs.sys files with the version from the Development Preview (you will need to change permissions/take ownership of files:
MountDir\Windows\System32\Drivers
MountDir\Windows\Winsxs
MountDir\Windows\System32\Driverstore\FileReposito ry
Dism /Unmount-Wim /MountDir:C:\Mount /Commit (Some people had to kill explorer.exe to do this as it kept locking the file. I did non need it)
Did this for both Install.wim and Boot.wim, no bluescreen on AMD RAID/AHCI now.
- Bsod windows 8
