JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Solved BSOD again after a few months...
Hi all.
This time I got a red screen and my pc restart by himself. I was playing more than an half hour Crysis 3. The second time there was no problem, I played a few minutes, but while playing the game it stutters a lot. Maybe you have an idea what it could be the red screen? Good to know is that I have 3 x 4 = 12 GB DDR3 RAM (I think that's enough memory for doing all jobs)
OS
Windows 10 Pro 64Bit
AMD FX-8150 Black Edition, sAM3+ 3.60 GHz, Octa-Core, 16MB, 125W
Asus Sabertooth 990FX AM3+
Corsair Vengeance 32GB DDR3 kit (4x 8GB), CMZ32GX3M4X1866C10'
EVGA GTX 970 Superclocked ACX 2.0
Philips 32"PFL9606H/12
Samsung 850 Pro series 1 TB
It's graphics card error. (Red Screen of Death)
OS
Windows 10 Pro x64
INTEL Core i7-2700K 3.5GHz
ASROCK Fatal1ty P67 Main Board
HyperX Blu 8GB (2 x 4GB) DDR3 1600
Gigabyte GTX 980 Ti G1 Gaming
On-board
Philips Brilliance BDM4065UC
3840x2160
SSD: Samsung EVO 250 GB
Internal HDD: WD Black 1TB
External: 2x2TB MyBook drives
1x4TB MyBook
1x1TB Seagate Freeagent drive
Corsair GS 700W
Silverstone Kublai KL04
Artic Cooling Freezer Pro
Logitech G710+
Razer Mamba Elite 2012
FF 39.0.3, Microsoft Edge, Chrome 44
Avast 10.0
Oké. Should I better waiting till there's a new minidump file? I will continue gaming and watching movies.
OS
I played Cysis 3 so about 40-45 minutes and I'm glad to say nothing happened this time. I wait 2 days, if there nothing happens than I mark the problem as solved. Thanks all for you're help!
OS
After playing 27 minutes of Crysis 3 I get a red sreen of death again. What do you think it's the problem and how do I fix that?
OS
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
Oké, I'll do that and I let you know.
By the way, how long must I wait this burn-in test? Does it end from himself?
OS
I'm testing it now so about 40 minutes, there are no artifacts and the max. temp. of the gpu reached 80 degrees.
OS
You can stop the test. Please check if you have softOSD installed. If you do, remove it.
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
I stopped the test. SoftOSD? where can I find that? I looked for it but there is nothing named softOSD. What else can I do for this red screen of death? Thanks!
OS
As a program in Control Panel -> Programs and Features. Try using another driver version.
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
I don't understand it well. I can't find it. What must I delete or download another driver version? I looked in control panel - programs and features. I've got a program named SiSoftware Sandralite 2014, 's that what you mean or?
OS
No that's not the program I meant. Please try installing new drivers. You can just installed them over the old ones. Is your SiSoftware Sandra(or any other software) monitoring your system? More particularly your GPU? If, yo, please try removing it or disabling the monitoring part of the software as it is known to cause RSOD.
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
No, I don't have programs installed like that. I'll delete some unnecessary files.
OS
What are your in game temperatures?
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
I don't know. How can I check that?
OS
Using MSI AfterBurner software
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
i think it's normal, I used MSI AfterBurner, it shows max 69 degrees during gaming.
OS
That is normal. Have you tried installing another driver version?
OS
Windows 10 Pro x64
On-board
3840x2160
1x4TB MyBook
Corsair GS 700W
Logitech G710+
Avast 10.0
I got a new RSOD again. MSI AfterBurner was running and the pc restarted. I will look for new drivers of amd. See this picture below, this is bad, gaming for an half hour and than you get this.
OS
