Audio/Visual Stuttering
Russs
I have been experiencing stuttering both audio and video. This occurs after the computer has been running for two days (hibernating at night). For the first day it works perfectly, youtube, MPC, etc work flawlessly. Then towards the end of the second day, stuttering, with no apparent cause.
This stuttering occurs primarily when reloading the page in the browser, and starting a new video. Upon reloading there will be stutters for the first few seconds (accompanied by audio buzzing type feedback in tune with video stuttering).
I use chrome but it is not exclusive to that.
Graphics drivers are updated, issue persists.
Upon restarting the problem disappears, only to return next day.
Any suggestions (preferably software based, I am disabled, so cant go diving into the hardware)?
    PCSpecialist
    Intel® Core™i5 Quad Core Processor i5-3570 (3.4GHz) 6MB Cache
    ASUS® P8Z77-M: MICRO-ATX, USB 3.0, SATA 6GBs, ATI®CrossFireX
    8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 4GB KIT)
    2GB AMD RADEON™ HD7870 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
    ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
    LG IPS
    2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
    450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
    COOLERMASTER ELITE 430 BLACK CASE
    INTEL SOCKET LGA1155 STANDARD CPU COOLER
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
    Avast Pro Internet Security
Which browser are you experiencing this with ? Are you saying in a media player this occurs too ? Does not happen in Chrome.
Seems like either a possible electrical disturbance going on here. Also could be a hardware issue, PSU.
Not sure yet if it could be the video card. Have another monitor to try ? Say stuttering in audio, mean like a buzzing ?
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
Happens in chrome, firefox and MPC. Mostly in chrome as far as I can tell as its my main browser. Unfortunately not got another monitor to try.
The stuttering, the video will stutter for half a second or so (at a time), sometimes less sometimes more. Along with this stuttering the audio from the video also stutters, but continues; so as the video jerks forward by the millisecond so does the audio, causing a buzzing sound in tune with the videos audio.
It might be the other way around, the audio stuttering causing the video stuttering, I'm not quite sure unfortunately. But the audio is more noticeable.
Bit tricky to explain, but there ya go. It started a few weeks ago, the only thing I can note that might of been the cause was me running ccleaner. I'm doubtful that's the cause, or at least hopeful, as there is no restore point.
What I'm struggling to understand is why it only occurs after a day/two (hibernating for a good 8 hours at night) of use, and disappears on restart.
Edit: Looks like maybe DWM.exe? Was having an issue (still am), where DWM was using up to and over 100mb of memory. Starts off upon restart simple enough at around 0.9-10mb and slowly increases as time goes on, is this normal? I just noticed it stuttering now, only a little, and its at 60mb. I took a screenshot before of task manager while it was happening on a previous occasion, was around 60mb then too. Honestly this might just be a coincidence, but you never now. Any way to find out what's going on in that there desktop windows manager?
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
How exactly is it just playing a video ( movies,DVD,video file example- wmv,mpeg.) also music ( cd,mp3,) to see if this happens
in MPC ?
DWM is Desktop Windows Manager it is going to use alot of RAM it gives you all those effects like Aero.
What is dwm.exe And Why Is It Running?
Telling me you have Windows 7 or Vista. Common for this to use a lot of resources. Do not think this is the cause of your problem by far.
You are saying you always keep the PC on in hibernate, then bringing out of hibernate it it gone afterl you restart.
But for how long till it occurs again ?
Some hardware issues occur when the hardware is on for awhile, as parts get warmer. Since you do keep it on always, even though in hibernate.
Thinking either something is disturbing it through where it is plugged in, or problem with Video card or PSU (Power supply).
Is this in a surge protector ? Anyway to plug it in somewhere else in house to test for disturbance in outlet or something else close by it is causing interference ?
We need to try playing videos and music through other sources like DVD,CD for awhile other then internet, to know it is occuring the same way.
Possibility, but i am not sure could be your modem, if only online this occurs.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Not sure I understand your first question sorry, I'll try though! The stuttering occurs mostly in Youtube, as far as I can tell, since that is that is the player I use most. I also use MPC for playing video files, such as .mp4, .mkv, .avi, .wmv, etc. The issue is most pronounced in Youtube, just after reloading the page and starting a new video. It occasionally happens in MPC too.
I'm using W8. You say I always keep it on, but doesn't hibernate save my 'session' to my hard disk and then for all intents and purposes shuts down? Regardless, once restarting the issue seems to reoccur after a day and a half/two days.
Since I also play files through MPC and the issue occurs there (albeit less frequently) I'm fairly certain its not my online networking systems.
Unfortunately there's no way, at least easily, to move to a new power-socket. Yes there is a surge protector. And there's not really anything close by electrical at all that could offer interference; no TV, no stereos, nothing. Just the computer and the associated wires and peripherals.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
It's o.k., I meant not using the browser and playing any media files through your media player, just wanted to test it this way to make sure if it had to do with the browser or modem (router).
Possible problem with it happening on Youtube could be due to a missing browser plug in, like adobe flash. Using Mozilla do you have Adobe Flash plug in ? In Mozilla go to menu on top, in Tools select add-ons look in plug ins tell me if you have Adobe or other flash players listed there. There you can check for updates to them.
Sorry i was not too familiar with hibernation, you are correct computer shuts down keeping the last stuff you worked on into the RAM,so when you turn it back on all work is saved and can resume to what you last were working on.
Windows 8 has Windows Media player 12 did you try this or do you prefer Media Player Classic, as you listed it MPC ?
Are you downloading these videos from youtube also, then playing them in MPC ? Each video is different on youtube.
Might not have right audio or video codec required for playback.
No cell phones or other wireless devices near PC at anytime ? By you trying a different source like a DVD or CD was to try to rule out possibilities it is not your Video card or audio card. Still want to make sure, try playing one of these for awhile.
Intermitting problems can be difficult to find unless it happens all the time.
Try checking your plug ins first on each browser, i am not too familiar with Chrome, but i showed you how to check Mozilla.
Did you try IE ? Internet Explorer.
Do you have a program to clean the browser and cache history ? If not go to File explorer and right click drive then properties and select Disk Cleanup, should do this periodically.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Adobe/Shockwave flash enabled on both Mozilla, and Chrome. Initially I thought that might have been the offending issue since at the time I'd only noticed it in Chrome. After uninstalling, reinstalling, disabling, enabling, etc; found out it wasnt the cause, unfortunately.
I do prefer MPC yes, I'll try other players and see if the issue continues there, VLC, WMP, etc. Regarding playback codecs on specific Youtube videos, when the issue arises, it happens on all videos as far as I can tell.
I'll try and dig out a DVD to try.
The problem is intermittent as you say, but it is consistent as to when it returns, so there is that.
Recently did a disk cleanup in an attempt to fix this issue, no dice (although I did find out I had 40gb of previous windows installations so not a complete loss).
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
Same happens on DVDs, and on audio tests through control panel > sound > test. The audio tests I did with nothing going on, little stuttering/audio glitches, and when doing something fairly intensive. Audio glitches occurred more and with greater intensity when something else was going on. Like reloading a browser page.
With audio tests the stuttering turned into crackling sounds, not every test had these glitches, but enough to know theres something amiss.
Fairly convinced its an audio problem now.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
o.k. at least we know it is not just occurring in the browsers. Audio testing will only play a short sound, not long enough to determine, but did show the issue.
Is this a custom built PC ? Checking your PC specs i do not see a brand for your Audio Card. You can go to the Device Manager undoer "soud,Audio and game controllers" should list a name. Also when you tested the sound in control panel under sound should be listed as your default device.
Because i want to start off with trying to check for Driver updates for this integrated card. Even Video card which sometimes within it's software you can check for updated drivers or go to AMD's site. Not sure if custom built or i'd say go to manufacturer's site of the PC to check also.
Could also be due to some other outdated drivers,IDE controllers. Was Windows 8 installed on this PC when purchased ?
Why haven't you updated to Windows 8.1 ?
Use task manager under performance, do you see high percentage of CPU use ? Start up tab many enabled items listed and rated high system impact. Also check RAM usage.
Hve you recently ran a full system scan with your Avast ? Should do so if not.Not a quick scan.
Have you added any software or hardware just before this issue started happening ?
Do you have a system recovery partition on PC ?
Try running CHKDSK this will take some time.Then a scan disk.
from the elevated command prompt, type chkdsk c: /f /r
after that finishes and reboots,
again from the elevated command prompt, type: sfc /scannow
Want to see the results.
1. Press the Windows + R keys to open the Run dialog, type powershell.exe, and press Enter.
2. In PowerShell, copy and paste the command below, and press Enter.
get-winevent -FilterHashTable @{logname="Application"; id="1001"}| ?{$_.providername –match "wininit"} | fl timecreated, message | out-file Desktop\CHKDSKResults.txt
3. You will now have a CHKDSKResults.txt file created on your desktop that is the log file of your chkdsk scan results from Event Viewer.
Up to you to try this it will not hurt should be done periodically to check the health and repair problems with your HD.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Here are sites to check for latest downloads.
For audio which is a Realtek integrated card on this motherboard Motherboards - P8Z77-M - ASUS
Video card AMD Radeon? HD 7800 Series Graphics Cards
Was not sure if system is 32bit or 64bit, make sure choose right bit.
I do not see it as a realtek listed in your system specs here, check through your programs for it's settings, might be also in the control panel. If find make sure settings are correct, also check speaker jack connections on back of your PC make sure they are snapped all the way in.
As said earlier take a look at the list of audio devices in the Device manager under "Sound,video and game controllers", list them here or take a screen capture post it here.
Also i believe you were in sound in the control panel to test your audio, go to sound in control panel and in playback tab, speakers should be the default device, should be listed realtek. Again if you can screen capture to show what is there.
If you do not know how to screen capture, here it is.
While the window you want to capture is on screen, hit Ctrl and print screen at same time on keyboard.
Then open Windows paint and left click center of window, go to Paint menu and hit paste, then save as a JPEG.
Post it here through the manage attachments, below your typed post.
What would be good is if you can screen capture what you are seeing in video stuttering, post it also.
Hard to understand sometimes what is meant by stutter. Is it slowing down, freezing ? Sound part i kind of understand more so.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Updated Asus audio, although I think I had already, no harm in retrying though.
Device manager says AMD high def device and Reaktek high def device.
Recently done a full scan on avast. No hardware or software changes around the time of issue starting bar running ccleaner. Don't know if there's a system recovery partition.
Yes custom built but by professionals, I just chose the parts.
Running a chkdsk now, hopefully it doesn't take a week.
Not updated to 8.1 as I've heard there's teething issues.
No major cpu hogs in task manager.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
Five hours later and it is done, the chkdsk that is.
Attached screenshots of device manager, control panel > sound, and also attached the chkdskresults file.
  • CHKDSKResults.txt
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
Issue still persists a day and a bit after restart. Seems to occur when theres more bass.
Been playing a song on repeat that I can gauge a reasonable baseline from, on itunes. When a browser is open, firefox or chrome, the audio stutters/crackles, when said browsers are closed, nothing. Opening other intensive programs (not browsers), there are no glitches. This is as far as I can tell mind, it might just be a coincidence that browsers use a certain area of the computer I'm not sure.
Saw a suggestion of people having VERY similar issues here:
Fixed Windows 7 Sound (Popping, Cracking & Skipping) | Corey DeGrandchamp
No enhancements were in place, but I've noticed audiodg taking up highest amount of CPU when playback'ing.
Also downloaded and ran the latency checker suggested, when issue arises high latency is caused when browser tabs/multiple are opening, also maybe with Steam. There is also latency with other programs but they do not cause crackling, stuttering or static. No latency is experienced when the computer has restarted, just like there are no audio glitches. Seems to maybe be network based?
Maybe it has something to do with my Realtek PCIe GBE family controller, recently restarted so no way to check at the moment.
But seems similar to this persons problems:
PC Stutter, Latency, Realtek PCIe GBE Family Controller - Windows 7 Help Forums
Looking through latency checkers and xperview USBport.sys and ndis.sys seem to be using the most, but thats when there are no latency issues, not sure but will check when they pop up again.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
CHKDSK did find some stuff and corrected it. Did you also use scan disk ?
These are just good measures to do monthly,didn't really feel may cure your problems but make sure your drive is good.
This is getting deeper and it seems you are not saying your video is still causing you issues also.
Read article on Audiodg.exe not familiar with it as mine does not have this process, but believe may still need to be there.
This article is same as one you posted Fix Audiodg.exe High CPU Usage in Windows 7 | Windows EXE Errors
You should upgrade to Windows 8.1, plus update 2 coming soon. Updates will fix bugs in previous versions always recommended to take the updates. Again may not solve your issues at hand but most of updates help with security issues also.
Not familiar with latency. Seems to me a setting with your Audio device as said possible enhancement. Recheck settings within Realtek's control panel ( Audio Manager) Make sure Chrome and Firefox are up to date. True when you run more resources it gets worse.
Do not think that shutting off system or program files you see in task manager that may be important is going to solve the issue, but create more issues. As you did check your startup programs in MSCONFIG use CCleaner to identify them also, research them first.
Is your monitor hooked up with a HDMI cable ? Are you running audio through it ? Never asked what type of speakers you are using, this could also be the issue if something wrong with them. Way try them on another device or PC.
I will research more, but may either need to check your settings on this audio card closer, seek a Computer tech or bite the bullet and do a system recovery if you have a partition. Check with person who made the system for you if it has one.
Mostly these recovery partitions are hidden from you seeing them in disk management.
You can also try Windows 8 refresh or reset.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
This Audiodg.exe seems more and more to be the problem. Although i see no reference to it in Windows 8. As you read, it started in Windows Vista and went only till Windows 7 listed in all research online.
Also has to be some part of Realtek. Why i mentioned before to go into Realtek's Audio manager and look for Any kind of enhancements enabled. Enhancements effects like,example: hall, arena, concert. Anything like this checked in settings of Realtek.
This is what it sounds like to me, i had a similar realtek on my system integrated, but bought a separate PCI sound card.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
All enhancements are disabled.
Fairly certain its a latency problem now.
Using a pair of realtek speakers but issue persists through headphones and various jacks.
Updating to 8.1; I pray that something it brings fixes this.
Sfc /scannow found nothing amiss.
Using DPC latency checker and latencymon I've noticed that latency only arises with programs with an internet connection. Such as browsers, skype, etc. Although for some reason downloading the 8.1 update is not causing latency.
In latencymon the second highest driver user after usbport.sys is ndis.sys, both seem to be a direct cause of latency for many users. Although no direct fix is ever found, at least consistently. I'm connected via ethernet, all wireless adapters are disabled; just mentioning as wireless seems to be a cause for some. Updated my network adapters drivers too, no fix.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
0xC1900101 - 0x40017 update failed, joy of joys.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
Hi Russs, error from trying to update windows 8.1 ?
At first we were talking about possibility of your internet service, but considering this happens with Media players (MPC too)
Kind of ruled it out. usbport.sys is a system driver configures usb devices along with ndis.sys which is a microsoft driver, do not think you can stop them without causing you more problems. Seems these drivers are more relevant in Windows Vista and 7,then 8.
I can see since your problems get worse with higher CPU usage you are feeling some high resource item is causing your problem, but i am not sure that might be the case it may just add to it.
I would hold off on the Windows 8.1 Update for now, considering your issues. In case you have to do a refresh, reset or complete recovery from a partition to solve your problems, that would be a last resort.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Not sure about ruling out internet. Considering when it happens in MPC or itunes the browser, or some other internet related program, is also running and said issue is extremely pronounced when reloading a browser page.
    PCSpecialist
    LG IPS
    Logitech k360
    Logitech G700
    120mb/ps
    Chrome
Yes, but if problem occurs also without connecting to the internet fault can not just be from with the modem or router.
Seems more like something used by the browser ( ext., plug in).
So your meaning you can be using MPC playing something like a movie, CD or mp3 then open up your browser at the time and the problem gets even worse.
Never answered if IE does this except for Chrome and Firefox.
I asked once before if you are using HDMI, Display port to hook up your monitor. Both these carry audio signals also from a Sound device.
Never came across a problem were a modem or router caused sound issues. Talk to your provider of this, check there website.
May seem obvious when you run more resources this problem gets worse.
Besides checking what is running in process also check what starts up when you boot and stays running, in start up in task manager, tell you if it is high, low impact.
You can try a windows 8 refresh which will keep all you added since you bought it to see if it resolves the issue,but a reset is more were you will loose what you put on it already. It's a last resort unless still want to troubleshoot it more, something could be missing,corrupt or set wrong where you can not see it. Again might be your best solution would not hurt it, many have solved there problems this way and Windows 8 made it easier then doing a system recovery from a recovery partition which would take hours.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
