Solved Annoying problem with sound crackling and skipping
No problem. You should try running latencymon while listening to music or doing something that messes with the sound so you can check if something its causing high latency spikes when it pops/stutters. Its a really nice tool, far more detailed than DPC ever was, and will tell you exactly what is causing spikes. It could very well be a bad driver you can easily remedy
    Windows 8.1 Pro x64
    Lily
    intel 4790k@4.7
    msi z97 mpower max ac
    16gb ripjaws x @2133
    evga 980ti sc+
    creative sbz
    dell u3011
    840 evo 250 & 9tb
    evga supernova 1000
    corsair 750d
    corsair h110
    logitech g710
    logitech g502
    cable@110/15
    firefox
    webroot
Thanks, I'll check this out.
    windows 8 pro
    vaio sz4
    Intel core duo 2ghz
    Intel 945
    2 GB
    Nvidia go 7400
    Sigmatel High Definition Audio
    12800 x 800
    120 GB
Ok...now the interesting thing. I downloaded the Latencymon. True it showed that my NDIS Driver ( network ) has the highest latency time. So I tried to update it. Now it shows NDIS driver's latency fine but still get a crackling and stuttering sound...here's the screen pic: DPC.jpg
    windows 8 pro
    vaio sz4
    Intel core duo 2ghz
    Intel 945
    2 GB
    Nvidia go 7400
    12800 x 800
    120 GB
Also having High Latency issues am 100% sure this is a Microsoft Issue and they need to update windows.
Am getting same two drivers has you plus c-media and USBport 2.0
    Windows 8 Pro 64bit
You're definitely suffering from some extreme latency and I'm sure it has something to do with your issues. Does the current kernel latency stay at that level at all times? I've read that windows 8 has made some changes in the way the os timer works so maybe drivers need to catch up. What does the driver tab look like? There you can see exactly what driver is causing the issue.
For reference this is what mine looks like;
    Windows 8.1 Pro x64
    Lily
    intel 4790k@4.7
    evga 980ti sc+
    creative sbz
    dell u3011
    840 evo 250 & 9tb
    evga supernova 1000
    corsair 750d
    corsair h110
    logitech g710
    logitech g502
    cable@110/15
    firefox
    webroot
Ok. It looks like this is the culprit. NDIS.SYS. This driver or file takes almost 60% of the processor power causing huge spikes. How this can be fixed ? NDIS is located in system32, can it be modified or shouldn't be touched at all...?
    windows 8 pro
    vaio sz4
    Intel core duo 2ghz
    Intel 945
    2 GB
    Nvidia go 7400
    12800 x 800
    120 GB
The thing is that it could be almost anything causing that ndis latency. Any app or device accessing the web could be causing it. The thing I would try first is to disable all power saving features. A few include;
Setting the pc to high performance mode in power profiles
Disabling "allow the pc to turn off device" in device properties for nic, audio and usb
Disabling "green power" and all wake options in nic device properties and also manually setting speed instead of using auto
Disabling C-states and power savings in bios and if needed core parking in windows
Also to minimize audio pops and weird sounds mute all non used inputs and outputs in sound properties. This makes a huge difference in cleaning up audio
    Windows 8.1 Pro x64
    Lily
    intel 4790k@4.7
    evga 980ti sc+
    creative sbz
    dell u3011
    840 evo 250 & 9tb
    evga supernova 1000
    corsair 750d
    corsair h110
    logitech g710
    logitech g502
    cable@110/15
    firefox
    webroot
Thanks. I've tried every step you suggested for me to do. Nothing helps so I think although my comp supports 64bit architecture it's simply not up to the par with 64bit systems.I think the chipset causes spikes etc. So maybe we should leave the topic and I should buy a new comp that will suport better 7 and 8.
    windows 8 pro
    vaio sz4
    Intel core duo 2ghz
    Intel 945
    2 GB
    Nvidia go 7400
    12800 x 800
    120 GB
Sorry to bump this again but i noticed something I should share. With the latest network driver at realtek.com I notice 1-2ms ndis spikes every few seconds on both windows 7 and 8. With the latest driver from windows update there are no spikes at all. Maybe you guys can try that out as well
    Windows 8.1 Pro x64
    Lily
    intel 4790k@4.7
    evga 980ti sc+
    creative sbz
    dell u3011
    840 evo 250 & 9tb
    evga supernova 1000
    corsair 750d
    corsair h110
    logitech g710
    logitech g502
    cable@110/15
    firefox
    webroot
Ok that was the bummer. It's all appeared that Windows 8 is not so much of a culprit actually. It's working absolutely fine as a 32bit installation on my comp. So it simply sppears that Windows 8 64bit demands the better hardware I mean not older than a 2 year comp probably and a bit newer drivers for Windows 8. I've been trying all the features for 2 days and sound etc. are working fine.
La Fin...thanks to all.
    windows 8 pro
    vaio sz4
    Intel core duo 2ghz
    Intel 945
    2 GB
    Nvidia go 7400
    12800 x 800
    120 GB
This is what I get in Windows 8 with my 4 year old desktop. I don't always get the pops and skipping. Wish I could figure this out.
I haven't read through the whole thread so I don't know what you've tried, but the Ethernet controller is usually a big culprit.
Go into device Manager, and expand Network Adapters. Find your Ethernet controller and rt. click it, then select disable.
    Toshiba Satellite
    Intel Core Duo P7450 @ 2.13GHz
    4Gb
    ATI Raedon HD3650
You should try the following. The Power plan set to high perfomance, as this will reduce DPC latency. DPC latency may be the cause of why it occurs crackling sound.
    Linux Ubuntu and Windows 7 and 8.1
